SD library SPI pins remap
ChoCho
Post by ChoCho »
Hi everyone,
I use a Generic STM32F103C8T6 to do a project. My project use the standard arduino SD library to read/write data, but the default SPI pins (PA4-PA7) are used for other purpose.
It seems that there is another set of SPI pins (PA15,PB3-PB5) that can be used, but I can't found any information how to use it instead of the default SPI pins.
Is it possible to use these pins to work with the SD library ? Thank you for any help !
Re: SD library SPI pins remap
.rpv
Post by .rpv »
On the ST core you can remap the spi, i2c and serial pins: https://github.com/stm32duino/wiki/wiki/API#spi
You can also can use a different library, the default arduino SD library only supports the default SPI, but on other libraries you can use a different SPI port.
ChoCho
Post by ChoCho »
Thank you all, I am using the STM32F1/F4 core files (Leaflabs-based core).
I have some working codes based on the standard SD library, changing to another SD library involve to much work and not preferred.
You can call in setup
afio_remap(AFIO_REMAP_SPI1);
Another option wold be to use SPI2 interface, pins PB12/13/14/15.
In this case you only need to call in setup
SPI.setModule(2);
before SPI.begin() and it should work.
PS. Admin, please move this under "LIbmaple" core section. Thanks. --> done ;)
ChoCho
Post by ChoCho »
The SPI2 method works !
But the SPI1 remap method do not work.
Here are the codes I use :
#include <SPI.h>
#include <SD.h>
  Serial.begin(57600);
  Serial.println("Boot ...");
  delay(50) ;
//    using alternate SPI1 pins
//  CS=PA15, SCK=PB3, MISO=PB4, MOSI=PB5
  if (!SD.begin(PA15))
    Serial.println("SD initialization failed !");
    while (1) ;
  else
      Serial.println("SD OK");
For the CS pin you use PA15.
Instead, you could use any other pin as well.
This PA15 is a special pin because is per default reserved for debugging.
In order to use it as normal IO pin you have to call
enableDebugPorts();
in your setup. I am not sure about the order relative to remapping, just try both ways (before and after) and let us know which works.
And don't forget to set the CS pin as OUTPUT! ;)
ChoCho
Post by ChoCho »
I added enabledebugPorts() in setup, but during compilation it said : 'enabledebugPorts' was not declared in this scope.
stas2z
Answers: 8
Post by stas2z »
ChoCho wrote: Sun Apr 12, 2020 9:49 am I added enabledebugPorts() in setup, but during compilation it said : 'enabledebugPorts' was not declared in this scope.
enableDebugPorts();
ChoCho
Post by ChoCho »
I corrected to enableDebugPorts() and compilation OK. But SD is failed.
I tried using other pins as CS (PA11 or PA12 or PB8), for example :
  pinMode(PA11, OUTPUT);
//  connections : MOSI= PB5,  MISO=PB4,  SCK=PB3, CS=PA11
if (!SD.begin(PA11))
    Serial2.println("DC16(0,48,'SD initialization failed !',1);");
    SD_ok = false ;
    while (1) ;
  else
      Serial2.println("DC16(0,48,'SD OK !',1);");
but SD still not work.
