Maple Mini (clones) - Programming from [.bin] with [usb]
Stophe
Re: Maple Mini (clones) - Programming from [.bin] with [usb]
Post by Stophe » Thu Aug 06, 2015 11:10 am
This is what I got, there is a few differences actually :
A:\Stophe>dfu-util -l
dfu-util 0.8
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2014 Tormod Volden and Stefan Schmidt
Please report bugs to dfu-util@lists.gnumonks.org
Found DFU: [1eaf:0003] ver=0201, devnum=4, cfg=1, intf=0, alt=1, name="DFU Program FLASH 0x08005000", serial="LLM 003"
Found DFU: [1eaf:0003] ver=0201, devnum=4, cfg=1, intf=0, alt=0, name="DFU Program RAM 0x20000C00", serial="LLM 003"
and
D:\Temp\build1002012548081470735.tmp>dfu-util -d 0x1EAF:0x0003 -a 1 -D sketch_aug06a.cpp.bin -R
dfu-util 0.8
Invalid DFU suffix signature
A valid DFU suffix will be required in a future dfu-util release!!!
Opening DFU capable USB device...
ID 1eaf:0003
Run-time device DFU version 0110
Claiming USB DFU Interface...
Setting Alternate Setting #1 ...
dfuIDLE, continuing
DFU mode device DFU version 0110
Device returned transfer size 1024
Copying data from PC to DFU device
Download [=========================] 100% 12100 bytes
Download done.
Done!
acutally my previous .bat file was doing
dfu-util -a1 -d 0x1EAF:0x0003 -D prg.bin
which is maybe a mistake. (the blank space missing or the -R missing). I get the Com port back for a while.
So I got the arduino IDE to write this :
Edit: I recompiled, I lost the message and it's not coming back. I'll reboot my computer, and redo those few steps.
Post by RogerClark » Thu Aug 06, 2015 12:08 pm
you are using an incompatible version of dfu-util
it only works with the version in the repo.
Stophe
Post by Stophe » Thu Aug 06, 2015 3:10 pm
My bad !
So right now I have what you had :
Found DFU: [0x1eaf:0x0003] devnum=255, cfg=0, intf=0, alt=0, name="DFU Program R
AM 0x20000C00"
Found DFU: [0x1eaf:0x0003] devnum=255, cfg=0, intf=0, alt=1, name="DFU Program F
LASH 0x08005000"
But there, the same message as from arduino
Found Runtime: [0x1eaf:0x0003] devnum=255, cfg=0, intf=0, alt=1, name="DFU Progr
Setting Configuration 1...
Setting Alternate Setting ...
Determining device status: error get_status: usb_control_msg: sending control me
ssage failed, win error: Un pÚriphÚrique attachÚ au systÞme ne fonctionne pas co
rrectement.
Edit : currently googling the thing... which is not really a success.
Post by RogerClark » Thu Aug 06, 2015 10:03 pm
very strange
try another cable
try another usb port
try a different computer that does not have too much other development software etc on it.
Post by zmemw16 » Thu Aug 06, 2015 10:33 pm
RogerClark wrote:you are using an incompatible version of dfu-util
spotting this i went off to check what i've got installed .... /usr/bin has
-rwxr-xr-x 1 root root 13936 Oct 4 2014 dfu-prefix
-rwxr-xr-x 1 root root 13952 Oct 4 2014 dfu-suffix
-rwxr-xr-x 1 root root 43000 Oct 4 2014 dfu-util
stephen@i7:/usr/bin$ ./dfu-util
dfu-util 0.8
attempting to run from tools/linux/dfu-util gives
stephen@i7:~/sketchbook_stm32/hardware/Arduino_STM32/tools/linux/dfu-util$ ./dfu-util
bash: ./dfu-util: cannot execute binary file: Exec format error
stephen@i7:~/sketchbook_stm32/hardware/Arduino_STM32/tools/linux/dfu-util$ file *
dfu-prefix: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, for GNU/Linux 2.6.32, BuildID[sha1]=00bf7e97d0c1f723bf4fd42b15e4e604faed5623, not stripped
dfu-suffix: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, for GNU/Linux 2.6.32, BuildID[sha1]=6a2247e79caa6ce6791dd0fef8a63a7e4290bab2, not stripped
dfu-util: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, for GNU/Linux 2.6.32, BuildID[sha1]=c58354ce3ca661a39bc97aacb5beffa73cf5dfb3, not stripped
any chance of x86-32 ? or does the debian package dfu-util_0.8-1_i386.deb suffice ?
/usr/bin/dfu-util does report devices correctly.
Post by RogerClark » Thu Aug 06, 2015 10:41 pm
Stephen,
Thats odd.
I thought the version in the repo, was the 32 bit version that I compiled on my Linux mint x32 machine.
The source for dfu is in the repo.
look in tools/src and recompile it, and see if that fixes it for you.
Note. look in the wiki, there are instructions for downloading and building the latest copy of dfu util etc,
but the sources in the repo should be fine, as they were updated yesterday with a Pull Request by @fergul to address an issue with the line endings in the automake or autoconfig scripts.
Post by zmemw16 » Fri Aug 07, 2015 12:43 am
oh it gets better...
most surprised by root password request and seeing apt-get being run.
i was expecting something like wget for a tgz && tar xpf dfu*.tgz && cd dfu-util && ./autogen.sh ...... etc etc type of invocation
stephen@i7:~/sketchbook_stm32/hardware/Arduino_STM32/tools/src$ ./build_dfu-util.sh
Reading package lists... Done
Building dependency tree
Reading state information... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
build-essential is already the newest version.
libusb-1.0-0-dev is already the newest version.
autoconf is already the newest version.
automake is already the newest version.
autotools-dev is already the newest version.
./build_dfu-util.sh: line 8: cd: dfu-util: No such file or directory
./build_dfu-util.sh: line 9: ./autogen.sh: No such file or directory
./build_dfu-util.sh: line 10: ./configure: No such file or directory
make: *** No targets specified and no makefile found. Stop.
cp: cannot stat ‘src/dfu-util’: No such file or directory
cp: cannot stat ‘src/dfu-suffix’: No such file or directory
cp: cannot stat ‘src/dfu-prefix’: No such file or directory
now i've copied dfu-util directory from your 060815-0842 build of yesterday, which has the source files in it
NB build-essentials should actually be build-essential, changed it here
now it builds and file shows
dfu-util: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux.so.2, for GNU/Linux 2.6.32, BuildID[sha1]=9224b7d0baa7b7dca954890f70197ccc032f42a5, not stripped
istr target format is an option to configure
i thought it was going to install the deb src package into dfu-util and build from that. so i'm off to google how that's done
are you running a debian x64 system?
trying to be helpful i thought i'd attach my build tree
nope - different story tgz too large at 430k so i split the file, parts have invalid file extension
tried to the binaries - Invalid file extension: dfu-prefix
copied and renamed to *.bin - Invalid file extension: dfu-prefix.bin
Post by RogerClark » Fri Aug 07, 2015 12:51 am
I'm running Linux Mint x32
There are at least 2 other Linux users, @ahull and @RickKimball , but I'm not sure what flavours of linux they use
Actually 99% of the time I use WIndows, I just tripple boot on of my machines to test Linux stuff when necessary
fredbox
Post by fredbox » Fri Aug 07, 2015 3:24 am
Linux Mint 17.2 Cinnamon 64 bit user here.
No issues at all uploading to the Maple mini board.
Occasionally, I have to press reset while uploading, but most of the time it works just fine.
I started out by doing a git clone of Roger's repo. About once a week (or after he has posted an update) I do a git pull to load the latest changes.
Board: Maple Mini
Bootloader Version: "Bootloader 2.0 (20k RAM. 120k Flash)"
Sketch uses 20,628 bytes (16%) of program storage space. Maximum is 122,880 bytes.
Global variables use 4,384 bytes of dynamic memory.
dfu-util 0.8
ID 1eaf:0003
Setting Alternate Setting #2 ...
dfuIDLE, continuing
dfu-util: Invalid DFU suffix signature
dfu-util: A valid DFU suffix will be required in a future dfu-util release!!!
Download	[                         ]   0%            0 bytes
... (bunch of lines deleted) ...
Download	[=========================] 100%        20628 bytes
Download done.
Done!
martinayotte
Post by martinayotte » Fri Aug 07, 2015 3:27 am
I'm actually an Linux 64bits user.
It it can help, here is dfu-util-0.7.zip, although I didn't follow the whole thread.
dfu-util-0.7.zip
(51.21 KiB) Downloaded 73 times
