Error led pin working with BluePill ?
michael_l
Post by michael_l » Thu Jun 15, 2017 8:51 am
Seems error led pin works with Maple Mini. If my code crashed led starts the fade in/out loop. But this doesn't seem to work with Blue board. Any way to enable it ?
RogerClark
Re: Error led pin working with BluePill ?
Post by RogerClark » Thu Jun 15, 2017 10:46 am
Thats an interesting point.
I have seen that LED flash on the Maple Mini, but it probably does not work on other boards
There is code in cores/maple/libmaple/util.c
That uses these defines
ERROR_LED_PORT
ERROR_LED_PIN
Try modifying boards.txt around line 179 in the genericSTM32F103C section and below the line
genericSTM32F103C.upload.auto_reset=true
add these 2 new lines
genericSTM32F103C.build.error_led_port=GPIOC
genericSTM32F103C.build.error_led_pin=13
Let me know how you get on, as I may add this to the core, as most people who use a genericSTM32F103C are actually using a BluePill
michael_l
Post by michael_l » Thu Jun 15, 2017 11:31 am
Yes, there seems to be a function in util.c 'throb' that gets called when abort occurs with a comment saying it fades the error LED on and off.
I'll report back after I've tested this.
RogerClark
Post by RogerClark » Thu Jun 15, 2017 9:21 pm
Yes.
I think its that function.
BTW. There is also code to send a debug message about the error via the hardware serial, but I have never tested it, so I am not sure if it works.
I think it may use Serial2
michael_l
Post by michael_l » Sun Jun 18, 2017 5:21 pm
Yes.
Yes, this works. It is kinda cool :-) I have blinking led with this line that results in "crash":
*((unsigned int*)0) = 0xDEAD;
But strange enough this :
int i = 1 / 0;
didn't crash my program.
RogerClark
Post by RogerClark » Sun Jun 18, 2017 9:17 pm
Did you try the Serial 2 error text output ?
Re: 1 / 0
umm. Do you mean no crash at all, or an unhandled crash
michael_l
Post by michael_l » Thu Jun 22, 2017 9:50 am
Re: 1 / 0
No, didn't try Serial2 yet. Based on the code it triggers only when an 'assert' fails.
I mean no crash at all, I was expecting the processor to abort and stop because that's a division by zero.
