#ifdef not working
geologic
#ifdef not working
Post by geologic »
Hi all
In Arduino IDE i have this at my main code:
#define TODAY
#include "todayLib.h"
and this on my todayLib.c library file:
#ifdef TODAY
	Serial.print("Now is Today");
#else
	Serial.print("Now is not Today");
If i run this code i see "Now is not Today", so it seems my #define TODAY is not being recognized inside my library.
If i move the #define TODAY into todayLib.h, it works as expected.
Is this a normal behavior?
I want to adapt my library to work with two different boards, so how do i define something on my main code that runs different parts of my library?
Re: #ifdef not working
That is normal, when the c file include the h file, your #define is not present.
To get your define available globally you should pass it as a global definition in your commande line -DTODAY or something like that.
Vassilis
Post by Vassilis »
geologic wrote: Tue Dec 05, 2023 5:17 pm ...
Maybe you can pass your board type as a parameter to your library constructor.
todayLib.h
    void begin(uint8_t myboard = 1); /* By default, board 1 is been selected. */
todayLib.c
void todaylib::begin(uint8_t myboard){
    switch(myboard ){
        case 1:
            <board 1 is selected>
        break;
        case 2:
            <board 2 is selected>
        break;
main sketch
todayLib mylib;
mylib.begin(); /* board 1 is selected */
mylib.begin(1); /* board 1 is also selected */
or
mylib.begin(2); /* board 2 is selected */
Vassilis Serasidis
https://www.serasidis.gr
it may work if you #include "todayLib.c" instead ( of "todayLib.h" )
