[Solved] Anybody using this F4 board and got the USB working?
flodejr
Post by flodejr » Sat Oct 07, 2017 2:30 pm
Is anybody using this F4 board?
I can get the usb to connect as DFU but it can't work as USB device.
Are there any special requirements to work as a device?
Re: Anybody using this F4 board and got the USB working?
Post by stevestrong » Sat Oct 07, 2017 4:13 pm
Where did you get it from? Aliexpress/Ebay link?
Any documentation available?
I ma not sure, but it looks like a generic mini board: http://wiki.stm32duino.com/index.php?ti ... 7VET6_Mini
flodejr
Post by flodejr » Sat Oct 07, 2017 5:28 pm
I got it from ebay.
Think this is the schematics i found on the net.
Post by stevestrong » Sun Oct 08, 2017 9:02 am
It seems to be a very "basic" F4 version, without any additional chips on it.
Unfortunately the picture is very small size, hardly readable.
Can you post the ebay link?
flodejr
Post by flodejr » Mon Oct 09, 2017 12:45 am
This is the ebay link
http://www.ebay.com/itm/STM32F407VGT6-A ... 1702413371
and link for the schematics.
http://dubstylee.net/v/wp-content/uploa ... 07VGT6.png
Post by stevestrong » Mon Oct 09, 2017 8:26 am
I don't see any resistor on the USB_DP pin to be connected to Vcc. It should be one there with 1.5kOhm.
You mean is does not work as USB serial?
What/how did you try?
Post by RogerClark » Mon Oct 09, 2017 9:07 am
Steve,
I don't think the 1.5k is necessary on the F4. Its supposed to be inside the MCU
flodejr
Post by flodejr » Mon Oct 09, 2017 9:20 am
I tried by using the cubemx and then specifying CDC Comms for USB_FS but no comm port appear both in linux and windows. I also tried the internal pull up on the DP like, but the comm port doesn't appear. When I put boot1 to 0 and boot0 to X, the DFU appears on both linux and windows.
flodejr
Post by flodejr » Mon Oct 09, 2017 9:21 am
Steve,
I tried the internal pull up on the MCU, but it doesn't bring up the USB port, I think maybe I need to wire a 1.5K resistor externally. WIll there be a problem since there are no 22ohm terminating resisotrs on the DP and DM lines?
Post by stevestrong » Mon Oct 09, 2017 11:39 am
Makes sense, otherwise it would not work as DFU either.
I cannot help with Cubemx.
But I think it should work out of the box using the generic F4 board variant of the libmaple core.
