stm32f407 black board with spi ili9341 ?
Limited support for STM32F4 Discovery, Nucleo and custom F4 boards
minime
Post by minime » Mon Oct 23, 2017 12:50 am
i am trying to use stm32f407 black board with spi ili9341, any suggestions if already done and on which branch ? regards
Re: stm32f407 black board with spi ili9341 ?
Post by stevestrong » Mon Oct 23, 2017 8:28 am
It should work out of the box if you copy the Adafruit_ILI9341_STM lib from F1 folder to F4 folder and configure the correct SPI port.
But it was not tested, so no 100% guarantee.
minime
Post by minime » Tue Oct 24, 2017 2:34 am
I tried that it gives
C:\arduino-1.8.2\hardware\Arduino_STM32-master\STM32F4\libraries\Adafruit_ILI9341_STM\Adafruit_ILI9341_STM.cpp:11:28: fatal error: wiring_private.h: No such file or directory #include "wiring_private.h"
so I installed danieleff/STM32GENERIC , it gives no erroers when complied that ili9341 example i will wire the lcd to the board and test, this branch well produced and easier to code with it, will update the results this week.
Post by stevestrong » Tue Oct 24, 2017 8:48 am
Fixed with this PR: https://github.com/rogerclarkmelbourne/ ... 2/pull/364
For this to work correctly, you also have to copy the Adafruit_GFX_AS lib from F1 folder.
