Analog pin reading
mebab
Answers: 4
Analog pin reading
Post by mebab »
Sorry if my question looks so simple to you!
I have been trying to read analog values connected to the pin PC4 in STM32L476. When I change values (0 - 3.3 V), I just can see either 0 or 1023. It cannot show equivalent integer values for analog voltages as they are! I use Arduino IDE and have define pinMode (PC4, INPUT) and use analogRead(PC4) to read the pin voltage. It seems that it considers the pin as a digital pin.
What is wrong with this simple task?
Thanks in advance,
by fpiSTM » Wed Jun 02, 2021 4:02 pm
What is your VREF on your boards ?
Any schematics ?
mlundin
Re: Analog pin reading
Post by mlundin »
Should work, can you show circuit diagram and complete code ?
mebab
Answers: 4
Post by mebab »
Thanks Mlundin,
I use ST-Link to program my board. Therefore, to see the results, I use LoRa simple node example to send the value of reading to a receiver to read it. The following is the code for the node:
#include <SPI.h>              // include libraries
#include <LoRa.h>
const long frequency = 433E6;  // LoRa Frequency
const int CS_LoRa = PC7;          // Pin 38 - LoRa radio chip select
const int resetPin = PB8;        // Pin 61 - LoRa radio reset; This is 9 in Library .h file
const int irqPin = PA10;          // change for your board; must be a hardware interrupt pin
  Serial.begin(115200);                   // initialize serial
  while (!Serial);
  LoRa.setPins(CS_LoRa, resetPin, irqPin);
  if (!LoRa.begin(frequency)) {
    Serial.println("LoRa init failed. Check your connections.");
    while (true);                       // if failed, do nothing
  Serial.println("LoRa init succeeded.");
  Serial.println();
  Serial.println("LoRa Simple Node");
  Serial.println("Only receive messages from gateways");
  Serial.println("Tx: invertIQ disable");
  Serial.println("Rx: invertIQ enable");
  Serial.println();
  LoRa.onReceive(onReceive);
  LoRa.onTxDone(onTxDone);
  LoRa_rxMode();
  pinMode(PC4, INPUT);
  if (runEvery(3000)) { // repeat every 1000 millis
    String message = "Vb =  ";
    int VB= analogRead(PC4);
    message += VB;
    LoRa_txMode();
    LoRa_sendMessage(message); // send a message
void LoRa_rxMode(){
  LoRa.enableInvertIQ();                // active invert I and Q signals
  LoRa.receive();                       // set receive mode
void LoRa_txMode(){
  LoRa.idle();                          // set standby mode
  LoRa.disableInvertIQ();               // normal mode
void LoRa_sendMessage(String message) {
  LoRa_txMode();                        // set tx mode
  LoRa.beginPacket();                   // start packet
  LoRa.print(message);                  // add payload
  LoRa.endPacket(true);                 // finish packet and send it
void onReceive(int packetSize) {
  String message = "";
  while (LoRa.available()) {
    message += (char)LoRa.read();
  Serial.print("Node Receive: ");
  Serial.println(message);
void onTxDone() {
  Serial.println("TxDone");
  LoRa_rxMode();
boolean runEvery(unsigned long interval)
  static unsigned long previousMillis = 0;
  unsigned long currentMillis = millis();
  if (currentMillis - previousMillis >= interval)
    previousMillis = currentMillis;
    return true;
  return false;
and this is the receiver:
#include <LoRa.h>
const int CS_LoRa = 10;          // LoRa radio chip select
const int resetPin = 3;        // LoRa radio reset; This is 9 in Library .h file
const int irqPin = 2;          // change for your board; must be a hardware interrupt pin
  while (!Serial);
  Serial.println();
  Serial.println("LoRa Simple Gateway");
  Serial.println("Only receive messages from nodes");
  Serial.println("Tx: invertIQ enable");
  Serial.println("Rx: invertIQ disable");
  Serial.println();
  LoRa_rxMode();
  if (runEvery(5000)) { // repeat every 5000 millis
    String message = "HeLoRa World! ";
    message += "I'm a Gateway! ";
    message += millis();
    Serial.println("Send Message!");
void LoRa_rxMode(){
void LoRa_txMode(){
  Serial.print("Gateway Receive: ");
void onTxDone() {
  LoRa_rxMode();
    return true;
  return false;
About the circuit diagram, I just connect a potentiometer to a voltage source to change the measured voltage of the PC4.
This is what gateway receives (0 or 1023):
Gateway Receive: Vb =  1023
mlundin
Post by mlundin »
I am using a Nucleo 64 L476RG card, connects the A3 pin, dac out, to PC4.
STM32dino v2, select board Nucleo 64 and partnumber Nucleo L476RG
Arduino serial monitor
pinMode(PC4, INPUT); is not needed, analogRead does the pin configuration.
check the input voltage with a multimeter.
Following code works:
  delay(20);
  while (!Serial);
  delay(500);
  Serial.println();
  Serial.print("SETUP: ");
  Serial.println(BOARD_NAME);
  Serial.print("FLASH->ACR = 0x");Serial.println(FLASH->ACR,HEX);
  Serial.print("SystemCoreClock: ");
  Serial.println(SystemCoreClock);
  Serial.print("F_CPU: ");
  Serial.println(F_CPU);
  Serial.printf("RCC_CR 0x%08X \n", RCC->CR);
  Serial.printf("RCC_CFGR 0x%08X \n", RCC->CFGR);
  Serial.printf("RCC_PLLCFGR 0x%08X \n", RCC->PLLCFGR);
  static int outval = 0;
  analogWrite(A2,outval); /* full range 0-255 */
  outval += 10;
  if (outval > 255) outval = 0;
  delay(10);
    int VB= analogRead(PC4);  /* full range 0-1024 */
    message += VB;
  Serial.println(analogRead(PC4));
Answers: 92
What is exactly your board?
And which target you selected in the menu ? Nucleo L476 or generic L476 ? Tested both and it works fine.
Try a simple example like analogReadSerial example by replacing A0 by PC4 (note that in the example you do not need pinmode).
mebab
Answers: 4
Post by mebab »
I also have successfully tested Nucleo 64 L476RG card. It works fine.
However, I have developed several boards using STM32L476. I use generic L476 and there is no problem with other tasks like SPI, I2C. etc,
The problem arises with reading analog input values on all boards as I mentioned and I cannot figure out the reason!
I did another test while I set PC4 as output and I could change it via the code which means the connection is correct.
Do I have to apply any settings to ADC? I ask this because it looks like it doesn't consider the pin as Analog input and just shows the minimum (0) and maximum (1023) of 10-bit digital values!
mlundin
Post by mlundin »
Problem with analog inputs on this specific pin PC4 or on all analog input pins ?
The settings to the ADC is handled by the analogRead function.
mebab
Answers: 4
Post by mebab »
I just tested. The same problem also with other analog pins!
for analog voltage:
Vin < 1 volt, gives 0
Vin >1 volt, gives 1023
Answers: 92
Any schematics ?
mebab
Answers: 4
Post by mebab »
fpiSTM wrote: Wed Jun 02, 2021 4:02 pm What is your VREF on your boards ?
Any schematics ?
Thank you fpiSTM!
I don't have external connections to these pins (Vref+ and Vref-). However, it looks like that they are internally connected to Vcc and GND.
I tried to externally connect Vref+ to Vcc and seems that problem is solved now. Then, I think fpiSTM addressed the right point!
