IDE 2 won't flash on mac
beserge
Post by beserge »
Trying to flash my Daisy Seed from IDE2 on the mac.
I'm on the latest version of stm32duino. I'm using the DFU upload method (although I tried the stlink and that also failed).
On my system it doesn't show up under Port (although the stlink did show up there).
On my friend's system it showed up under Port, but he still got "No connection established" when trying to flash.
Any ideas? IDE 2 works fine on Windows, just seems to have some connection issue under macOS.
Re: IDE 2 won't flash on mac
Arduino IDE 2.0 doesn't want to work with STM32duino. Even older version (I think it was rc6), which worked fine, stopped working.
Answers: 109
It works I saw some bugs linked to IDE but that's all
Answers: 109
Anyway, I will try next week on our MAC.
But probably IDE 2 issue.
beserge
Post by beserge »
Thank you! Let me know what you find as we're helping a client to set this up.
Answers: 109
I've tested on a MAC Book Pro with macOS Big Sur (Version 11.5.2).
Arduino 2.0.2 and core 2.3.0.
I've used Adafruit Feather F405 and use DFU.
No issue.
You have to start your board in Bootloader mode with USB plugged then the board enter in DFU mode.
You have also to get the STM32CubeProgrammer installed as this method uses the cli to upload in DFU mode.
A DFU port is not shown in the Arduino IDE port menu as it is not a COM port.
You can try to use the STM32CubeProgrammer gui and select USB to see if you are able to connect.
You can also try this command:
system_profiler SPUSBDataType
You should see the STM32 BOOTLOADER device.
USB 3.0 Bus:
Host Controller Driver: AppleUSBXHCISPTLP
PCI Device ID: 0x9d2f
PCI Revision ID: 0x0021
PCI Vendor ID: 0x8086
STM32 BOOTLOADER:
Product ID: 0xdf11
Vendor ID: 0x0483 (STMicroelectronics)
Version: 22.00
Serial Number: 20593773354D
Speed: Up to 12 Mb/s
Manufacturer: STMicroelectronics
Location ID: 0x14600000 / 8
Current Available (mA): 500
Current Required (mA): 100
Extra Operating Current (mA): 0
beserge
Post by beserge »
Thanks for the help! It ended up being CubeProg on my computer. On the client's computer they needed to update their IDE2 version.
Answers: 109
OK fine.
Return to “IDE's”
