Disable system reset on USB connect/disconnect
mcu8484
Post by mcu8484 »
Does anyone know how to disable automatic system reset on USB CDC connect/disconnect in stm32duino?
Re: Disable system reset on USB connect/disconnect
There is no such thing. STMs do not need to reset on USB connect like AVR Arduino boards.
If your board resets then it's rather hardware related.
mcu8484
Post by mcu8484 »
There is no HW triggering reset. The issue appears to be the stm32duino USB CDC driver which takes a long time (>1s) in its ISR when the USB host connects/disconnects leading to watchdog timeout reset. Disabling the watchdog is not an option.
use a longer timeout for watchdog reset?
jacobli
Post by jacobli »
Do you want to directly disable automatic reset?
mcu8484
Post by mcu8484 »
jacobli wrote: Fri Jun 02, 2023 9:42 am Do you want to directly disable automatic reset?
Yes but I need to keep the watchdog active and not longer than 1s. I am guessing that the stm32duino USB CDC driver is doing some handshaking with the host when USB connect/disconnect but taking too long and triggers the watchdog reset.
It would be helpful if someone who knows the stm32duino USB CDC driver internals can point out a potential solution (e.g. where to insert watchdog reset call, etc.).
