I want to create a 'hex' file via 'STM32Duino' (Arduino sketch).
myksj1105
Post by myksj1105 »
hello. Nice to meet you.
What I want to do now is:
1. Can I put the 'STM32F103C8T6' firmware without giving the Arduino Sketch source code?
2. It was found that '.bin' and 'elf' files were created through Arduino sketch.
3. Can I create a 'hex' file through 'Arduino Sketch'?
4. Also, if I created a 'hex' file, how should I put the 'firmware'?
5. Can I put it through 'STM32 ST-LINK' program?
If you know, please help.
by ag123 » Thu Aug 10, 2023 7:36 am
which core are you using 'libmaple' core
e.g. this
or 'official' STM core
In both cases, you need to select st-link as upload method to build the sketch, that change the start location and memory layout
and in addition, did you try a 'blink' sketch? like this?
	pinMode(LED_BUILTIN, OUTPUT);
	digitalWrite(LED_BUILTIN, ! digitalRead(LED_BUILTIN));
	delay(500);
these are the 'basic' things, the led need to blink. then for Serial, make sure to select USB CDC ACM as Serial for the 'official' STM core.
Re: I want to create a 'hex' file via 'STM32Duino' (Arduino sketch).
normally, ST-Link and other (e.g. serial) flashers use the bin file,
but you can try things like
arm-none-eabi-objcopy --input-target=binary --output-target=ihex sketch.bin sketch.hex
myksj1105
Post by myksj1105 »
@ag123
Thank you for answer.
1) Isn't the .bin file 'bootloader' information?
2) Can you upload the .bin file?
No. .bin extension is for "binary". STM32 MCUs use binary files for firmware upload. You need .bin file if you want to upload firmware to STM32 MCU, unless you have an application that converts HEX file into binary format before uploading it.
like @GonzoG mentions, that bin file is your 'sketch', that is the firmware.
and if you are using a STM32F103C8T6,
you would need either a ST Link v2 dongle.
https://octopart.com/search?q=st-link+v ... SD&specs=0
or a 3.3v usb-uart dongle
https://www.sgbotic.com/index.php?dispa ... page_id=48
other intro stuff
the 'official' core is here
and the wiki is normally where to get started
myksj1105
Post by myksj1105 »
@GonzoG
@ag123
Thank you very much.
Thank you for your kind explanation.
I will leave a reply after testing.
thank you
myksj1105
Post by myksj1105 »
@GonzoG
@ag123
1. Open 'STM32 ST-LINK Utility'.
2. Connect the target.
3. After clicking the program 'verify'
4. I put the '.bin' file created in the Arduino sketch.
'bin file download url : https://drive.google.com/file/d/1dWZzM7 ... drive_link
5. But it doesn't work.
What's the reason?
if you are on Windows, you can try using STM32Cube programmer
to flash your binaries.
for the bin file normally, on the Ardunio IDE menu there is Sketch > Export compiled binary or some such, that should leave the bin file in your sketch folder.
myksj1105
Post by myksj1105 »
@ag123
1. I used the following files as boot.
'generic_boot20_pc13.bin'
2. I created a 'bin' file through the Arduino sketch.
3. JTAG connection was made through 'STM32CubeProgrammer'.
4. I put the 'bin' file, but it doesn't work.
- 'Is it a problem because of the serial function?'
did you use that st-link dongle as like discussed?
stm32f103xx needs to use that st-link dongle or a usb-uart dongle to program it.
if the programming succeeds but that the sketch didn't work, that is a different issue
note that the 'official' stm core is here
and the wiki is here
there is an 'old' (Libmaple) community core here and the wiki in the repository
there are some other cores / copies of the codes scattered around the internet which are likely forks of these original or that they may be different implementations.
then not least, there are 'clone' stm32f103 'like' chips which may not be made by ST, make sure you are using an original STM32 if you are after all using the original stm32 tools. then for the boards, check the chips, some vendors substitute different chips e.g. stm32f103c6 (only 32k flash) rather than the correct stm32f103c8 (64k flash) or better stm32f103cb (128k flash) chips. and some vendors substitute 'clone' chips on the boards
if you are new to stm32
get one of the Nucleo boards
https://github.com/stm32duino/Arduino_C ... -64-boards
like Nucleo F401RE
Nucleo F401RE
https://www.st.com/en/evaluation-tools/ ... 411re.html
then Adafruit has a board with much faster chip stm32f405
https://github.com/stm32duino/Arduino_C ... 2f4-boards
which is also used in the micropython board
https://store.micropython.org/product/PYBLITEv1.0
and Olimex has something similar
there are also other boards e.g. the stm32f401 / f411 'blackpill' type boards. etc. search the online markets for them.
these boards and chips are recommended because they have lots of sram and flash, and stm32f405 is fast, so that you won't need to worry about it mostly while getting started learning the mcu platform. STM32 is a large family of microcontrollers.
if you use the 'official' STM core
it would be much easier to switch between different microcontrollers in the family.
Then for boards, there are many with different stm32 chips and that extends further to 3d printer boards a lot of them use stm32 among the offereings.
