Yes, I suspect is is something in those other libraries - the sketch only start every fourth of fifth attempt on reset. And if Serial has a 64-byte buffer which it can't clear because interrupts are disabled, then I guess we'd be seeing this behaviour
FWIW: here's the whole sketch:
#include <LwIP.h>
#include <STM32Ethernet.h>
#include <PangolinMQTT.h>
IPAddress ip(192, 168, 1, 178);
PangolinMQTT mqttClient;
#define MQTT_HOST IPAddress(192, 168, 1, 21)
#define MQTT_PORT 1883
#define START_WITH_CLEAN_SESSION true
void onMqttConnect(bool sessionPresent) {
// Serial.printf("Connected to MQTT: Session=%d Max safe payload %u\n",sessionPresent,mqttClient.getMaxPayloadSize());
mqttClient.subscribe("stm32",0);
mqttClient.publish("stm32",0,false,std::string("Oh my god it works"));
void onMqttMessage(const char* topic, uint8_t* payload, struct PANGO_PROPS props, size_t len, size_t index, size_t total) {
PANGO::dumphex(payload,len);
void onMqttDisconnect(int8_t reason) {
Serial.printf("Disconnected from MQTT reason=%d\n",reason);
Ethernet.begin(ip);
Serial.print("IP: ");
mqttClient.onConnect(onMqttConnect);
mqttClient.onDisconnect(onMqttDisconnect);
mqttClient.onMessage(onMqttMessage);
mqttClient.setServer(MQTT_HOST, MQTT_PORT);
mqttClient.setWill("NUCLEO_DIED",2,false,"It's 'Alpha': probably sill some bugs");
mqttClient.setCleanSession(START_WITH_CLEAN_SESSION);
mqttClient.connect();
void loop() {}
