[SOLVED]Hardwaretimer do not work on Maple Mini
Ralf9
Post by Ralf9 »
I have test the code in this example:
https://github.com/stm32duino/STM32Exam ... llback.ino
The LED do not blink
Re: Hardwaretimer do not work on Maple Mini
You use the master of the library which has this change:
https://github.com/stm32duino/STM32Exam ... 0a3352f716
Use the last release then it should work with the last official release.
Or use the core repository which has the linked change.
Ralf9
Post by Ralf9 »
Thank you, when I insert this
MyTim->setMode(2, TIMER_OUTPUT_COMPARE);
before
MyTim->setOverflow(31*1000, MICROSEC_FORMAT);
then it works.
Is this needed
#if defined(TIM1)
  TIM_TypeDef *Instance = TIM1;
#else
 TIM_TypeDef *Instance = TIM2;
Or can I on the Maple Mini always use
and setMode with channel 2?
