DFU bootloader has errors on new BlackPill F411
Re: DFU bootloader has errors on new BlackPill F411
i'd guess u'd need to built it from source
the reason is that the PLL setups are intended for a different crystal, u'd need to edit those M, N, P, Q clock multipliers and rebuild.
https://github.com/Serasidis/STM32_HID_ ... ain.c#L245
those multipliers could be found in the variant files, or you could try a python script like this
viewtopic.php?f=41&t=78
note i found another one from weact
https://github.com/WeActTC/WeAct_HID_Bootloader_F4x1
edit:
ok i tried a build, i used my python script link above FHSE is defined as 25 mhz
FHSE: 25 m: 25 n: 192 p: 2 (RCC_PLLP_DIV2) q: 4 fusb: 48.0 fcpu: 96.0 << this is the entry used
FHSE: 25 m: 25 n: 384 p: 4 (RCC_PLLP_DIV4) q: 8 fusb: 48.0 fcpu: 96.0
FHSE: 25 m: 25 n: 432 p: 4 (RCC_PLLP_DIV4) q: 9 fusb: 48.0 fcpu: 108.0
FHSE: 25 m: 50 n: 384 p: 2 (RCC_PLLP_DIV2) q: 4 fusb: 48.0 fcpu: 96.0
oops i built from an 'incorrect' source
https://github.com/WeActTC/STM32_HID_Bootloader
^ note as i build from this one, I noted some strange looking codes that i'm not sure what it is trying to do
https://github.com/WeActTC/STM32_HID_Bo ... 4fd5e3R146
but weact did change some pin definitions as well
the pll multipliers are edited as above, not the weact ones
i've not tried it, i don't have a stm32f411 board
hid_bootloader.zip
hid_bootloader.bin
(10.16 KiB) Downloaded 243 times
david.prentice
Post by david.prentice »
And has no one done this yet ?
Surely if the STM32 IDE has "HID 2.2" as an official option for F4 targets, someone, somewhere has built the .BIN file.
In much the same way that there is a hid_generic_pc13.bin available for installing on a BluePill.
And lots of public videos, advice ... on how to install on a BluePill.
I can't believe that BlackPills have been on the market for about 2 years and that no one has built the hid_bootloader.bin file.
Or if they have, they don't say whether it works or not.
Googling for information about BlackPill Arduino uploads all seems to say ST-LINK or power-on RESET+BOOT0.
Yes, SWD works fine. Yes, DFU works with a 1% accurate HSI. Both involve external access to the BlackPill.
David.
david.prentice
That hid_bootloader.bin does not do anything.
It does not matter if you don't have a F411. You can build for both F401 and F411.
But I presume that you should build from https://github.com/Serasidis/STM32_HID_Bootloader and not from WeActTC
As far as I can see WeAct don't support HID 2.2 and apparently look for HID with a non-existent VID/PID
I require a HID 2.2 bootloader that corresponds to the VID/PID requested by the Arduino IDE.
As I said earlier. It is painless with the BluePill-F103
David.
ok i'd try a built from the original one, it seemed i'd need to update some pins e.g. boot1 to make this work
oops i'm running into various issues, the build completes with a binary. but i tried to 'blink' the led from within bootloader codes, it didn't.
david.prentice
No problem. I was just expecting that there would be many F411 users and that HID 2.2 was mature, proven and functional for F411 (and F401). i.e. members had built and used HID for months and years.
David.
AndrewBCN
Post by AndrewBCN »
david.prentice wrote: Mon Aug 30, 2021 2:17 pm No problem. I was just expecting that there would be many F411 users and that HID 2.2 was mature, proven and functional for F411 (and F401). i.e. members had built and used HID for months and years.
David.
FYI there is an entire section of this forum dedicated to discussing the HID bootloader. Unfortunately you started this thread with the wrong title and in the wrong section of this forum. :!:
Check here: viewforum.php?f=58
Also, summarizing: the DFU bootloader DOES NOT have errors on WeAct BlackPill STM32F411CEU6 boards, on the contrary, it works fine... as long as one follows the exact recommended procedure.
MrHazelnut
Post by MrHazelnut »
I have had a lot of trouble entering STM bootloader on weact blackpill v3 when pushing the buttons with my fingers. I can confirm that entering STM32 bootloader works flawless everytime if Im not using fingers (i.e not touching surrounding pins) when pushing BOOT0 and RST.
wanderlg
Post by wanderlg »
I don't know if I'm asking the question in the correct post, but I searched and didn't find this answer.
Is there a way to make the STM32F401 enter DFU mode through commands? ie: enter DFU mode via software.
Answers: 28
No. If it could be done, there wouldn't be need for HID bootloader.
if you write an arduino sketch that jumps to the on-chip DFU rom address it may work. I've never tried and not sure how.
but this means in effect, your sketch needs to start the DFU boot loader. There may be other complications as well, e.g. in principle you need to send a "usb reset", i.e.pull D+ / D- to GND for 10 ms and restore it. This is to tell the host to enumerate ports again.
Then you can try jumping to the on chip boot loader.
look in the ref manual as well, you may dig out some 'tricks', e.g. a soft boot0 then followed by NVIC_SystemReset(). But in the same way your sketch needs to do the job.
