SPI remapping
forfrends
SPI remapping
Post by forfrends »
Hello!
I want to connect nrf24l01 to stm32f103c8t6. It is standardly connected to pins PA5 (SCK1), PA6 (MOSO1), PA7 (MOSI1). I have these pins busy, I already ordered a printed circuit board, so I won’t be able to use them. SPI2 pins are also busy. At the same time, there is another SPI port on stm32f103c8t6, also under the number "1" (Why under the number "1" ???):
PB3 (SCK1), PB4 (MISO1), PB5 (MOSI1)
Question: how to indicate in the code what exactly these pins will be used for SPI?
Answers: 92
Re: SPI remapping
Which core you used ?
BennehBoy
Re: SPI remapping
Post by BennehBoy »
Some peripherals can be switched to 'alternate' pins, it's still the same peripheral though hence why it shows as SPI1 for both pin sets. How to do it depends on which core you've used, Rogers/Steve's maple based cores, or the official STM HAL based core.
forfrends
Re: SPI remapping
Post by forfrends »
All figured out. It was only necessary to update the library. In the new version of the library, you can specify pins SPI:
SPIClass SPI_3(PB5,  PB4,  PB3, PA15);
Answers: 92
Re: SPI remapping
Right. So your topic is solved?
forfrends
Re: SPI remapping
Post by forfrends »
Can't get it to work!
If I'm flashing a test sketch, then SPI works:
#include <SPI.h>
#define SPI2_NSS_PIN PA15   //SPI_2 Chip Select pin is PB12. You can change it to the STM32 pin you want.
//             mosi, miso, sclk, ssel
SPIClass SPI_2(PB5,  PB4,  PB3, SPI2_NSS_PIN); //Create an instance of the SPI Class called SPI_2 that uses the 2nd SPI Port
byte data;
  // Setup SPI 2
  SPI_2.begin(); //Initialize the SPI_2 port.
  SPI_2.setBitOrder(MSBFIRST); // Set the SPI_2 bit order
  SPI_2.setDataMode(SPI_MODE0); //Set the  SPI_2 data mode 0
  SPI_2.setClockDivider(SPI_CLOCK_DIV16);  // Use a different speed to SPI 1
  pinMode(SPI2_NSS_PIN, OUTPUT);
  sendSPI2();
  delayMicroseconds(10);    //Delay 10 micro seconds.
void sendSPI2()
  digitalWrite(SPI2_NSS_PIN, LOW); // manually take CSN low for SPI_2 transmission
  data = SPI_2.transfer(0x55); //Send the HEX data 0x55 over SPI-2 port and store the received byte to the <data> variable.
  digitalWrite(SPI2_NSS_PIN, HIGH); // manually take CSN high between spi transmissions
I checked with an oscilloscope, the data is being transmitted.
But if I connect the nrf24l01 library, the SPI port stops working. I am using the RF24 library: https://github.com/nRF24/RF24
Maybe you know a library that will work stably?
nopnop2002
Re: SPI remapping
Post by nopnop2002 »
If you are using STM32 Core, setClockDivider() will not work.
Because STM32 Core supports many CPU clocks.
setClockDivider() has a speed that depends on the CPU clock.
The following code will work with any CPU clock.
SPI.begin()
spiSettings = SPISettings(SPI_SPEED, MSBFIRST, SPI_MODE0);
SPI.beginTransaction(spiSettings)
SPI.transfer(data);
SPI.endTransaction()
