STM32F103C8T6 External Interrupt Problem
hyur
Post by hyur »
Currently, I am writing a code that operates the interrupt function when a falling edge occurs by connecting 3 buttons to the STM32duino by pull-up.
Interrupt registration looks like this:
attachInterrupt(digitalPinToInterrupt(PA0), button_ISR1, FALLING);
attachInterrupt(digitalPinToInterrupt(PA1), button_ISR2, FALLING);
attachInterrupt(digitalPinToInterrupt(PA2), button_ISR3, FALLING);
void button_ISR1()
  if (prevBTN[0] == HIGH)
    Serial.println("ISR R"); //Just Test Line
    button1_time_check = false;
    button1_Interrupt_flag = true;
void button_ISR2()
  if (prevBTN[1] == HIGH)
    Serial.println("ISR G"); //Just Test Line
    button2_time_check = false;
    button2_Interrupt_flag = true;
void button_ISR3()
  if (prevBTN[2] == HIGH)
    Serial.println("ISR B"); //Just Test Line
    button3_time_check = false;
    button3_Interrupt_flag = true;
There are 3 buttons, and when the button connected to PA0 is pressed, only the interrupt connected to PA0 should operate. But intermittently, all interrupts registered as PA0, PA1, PA2 are enabled.
I want to know the reason.
by hyur » Mon May 30, 2022 1:19 am
I solved the problem.
The cause was a circuit configuration problem.
Thank you.
Answers: 91
Re: STM32F103C8T6 External Interrupt Problem
Could you tell us which core you used and version?
Also, share your full sketch.
hyur
Post by hyur »
Thank you.
