Replaced SPI with SPI2 in the copy of Lora Library and getting below error
/private/var/folders/r7/3w_jcm0x57b7vn2yg1xm8b_x0wgj_5/T/.arduinoIDE-unsaved2023630-14465-1yfpjuh.lqx1/LoRaSender/LoRaSTM32C.cpp: In member function 'int LoRaClass::begin(long int)':
/private/var/folders/r7/3w_jcm0x57b7vn2yg1xm8b_x0wgj_5/T/.arduinoIDE-unsaved2023630-14465-1yfpjuh.lqx1/LoRaSender/LoRaSTM32C.cpp:82:8: error: request for member 'begin' in 'SPI2', which is of pointer type 'spi_dev*' (maybe you meant to use '->' ?)
SPI2.begin();
/private/var/folders/r7/3w_jcm0x57b7vn2yg1xm8b_x0wgj_5/T/.arduinoIDE-unsaved2023630-14465-1yfpjuh.lqx1/LoRaSender/LoRaSTM32C.cpp: In member function 'void LoRaClass::end()':
/private/var/folders/r7/3w_jcm0x57b7vn2yg1xm8b_x0wgj_5/T/.arduinoIDE-unsaved2023630-14465-1yfpjuh.lqx1/LoRaSender/LoRaSTM32C.cpp:121:8: error: request for member 'end' in 'SPI2', which is of pointer type 'spi_dev*' (maybe you meant to use '->' ?)
SPI2.end();
/private/var/folders/r7/3w_jcm0x57b7vn2yg1xm8b_x0wgj_5/T/.arduinoIDE-unsaved2023630-14465-1yfpjuh.lqx1/LoRaSender/LoRaSTM32C.cpp: In member function 'uint8_t LoRaClass::singleTransfer(uint8_t, uint8_t)':
/private/var/folders/r7/3w_jcm0x57b7vn2yg1xm8b_x0wgj_5/T/.arduinoIDE-unsaved2023630-14465-1yfpjuh.lqx1/LoRaSender/LoRaSTM32C.cpp:511:8: error: request for member 'beginTransaction' in 'SPI2', which is of pointer type 'spi_dev*' (maybe you meant to use '->' ?)
SPI2.beginTransaction(_spiSettings);
// Copyright (c) Sandeep Mistry. All rights reserved.
// Licensed under the MIT license. See LICENSE file in the project root for full license information.
#include "LoRaSTM32C.h"
// registers
#define REG_FIFO 0x00
#define REG_OP_MODE 0x01
#define REG_FRF_MSB 0x06
#define REG_FRF_MID 0x07
#define REG_FRF_LSB 0x08
#define REG_PA_CONFIG 0x09
#define REG_LNA 0x0c
#define REG_FIFO_ADDR_PTR 0x0d
#define REG_FIFO_TX_BASE_ADDR 0x0e
#define REG_FIFO_RX_BASE_ADDR 0x0f
#define REG_FIFO_RX_CURRENT_ADDR 0x10
#define REG_IRQ_FLAGS 0x12
#define REG_RX_NB_BYTES 0x13
#define REG_PKT_SNR_VALUE 0x19
#define REG_PKT_RSSI_VALUE 0x1a
#define REG_MODEM_CONFIG_1 0x1d
#define REG_MODEM_CONFIG_2 0x1e
#define REG_PREAMBLE_MSB 0x20
#define REG_PREAMBLE_LSB 0x21
#define REG_PAYLOAD_LENGTH 0x22
#define REG_MODEM_CONFIG_3 0x26
#define REG_RSSI_WIDEBAND 0x2c
#define REG_DETECTION_OPTIMIZE 0x31
#define REG_DETECTION_THRESHOLD 0x37
#define REG_SYNC_WORD 0x39
#define REG_DIO_MAPPING_1 0x40
#define REG_VERSION 0x42
// modes
#define MODE_LONG_RANGE_MODE 0x80
#define MODE_SLEEP 0x00
#define MODE_STDBY 0x01
#define MODE_TX 0x03
#define MODE_RX_CONTINUOUS 0x05
#define MODE_RX_SINGLE 0x06
// PA config
#define PA_BOOST 0x80
// IRQ masks
#define IRQ_TX_DONE_MASK 0x08
#define IRQ_PAYLOAD_CRC_ERROR_MASK 0x20
#define IRQ_RX_DONE_MASK 0x40
#define MAX_PKT_LENGTH 255
LoRaClass::LoRaClass() :
_spiSettings(8E6, MSBFIRST, SPI_MODE0),
_ss(LORA_DEFAULT_SS_PIN), _reset(LORA_DEFAULT_RESET_PIN), _dio0(LORA_DEFAULT_DIO0_PIN),
_frequency(0),
_packetIndex(0),
_implicitHeaderMode(0),
_onReceive(NULL)
// overide Stream timeout value
setTimeout(0);
int LoRaClass::begin(long frequency)
// setup pins
pinMode(_ss, OUTPUT);
// set SS high
digitalWrite(_ss, HIGH);
if (_reset != -1) {
pinMode(_reset, OUTPUT);
// perform reset
digitalWrite(_reset, LOW);
delay(10);
digitalWrite(_reset, HIGH);
delay(10);
// start SPI
SPI2.begin();
// check version
uint8_t version = readRegister(REG_VERSION);
if (version != 0x12) {
return 0;
// put in sleep mode
sleep();
// set frequency
setFrequency(frequency);
// set base addresses
writeRegister(REG_FIFO_TX_BASE_ADDR, 0);
writeRegister(REG_FIFO_RX_BASE_ADDR, 0);
// set LNA boost
writeRegister(REG_LNA, readRegister(REG_LNA) | 0x03);
// set auto AGC
writeRegister(REG_MODEM_CONFIG_3, 0x04);
// set output power to 17 dBm
setTxPower(20);
// put in standby mode
idle();
return 1;
sleep();
// stop SPI
SPI2.end();
int LoRaClass::beginPacket(int implicitHeader)
idle();
if (implicitHeader) {
implicitHeaderMode();
} else {
explicitHeaderMode();
// reset FIFO address and paload length
writeRegister(REG_FIFO_ADDR_PTR, 0);
writeRegister(REG_PAYLOAD_LENGTH, 0);
return 1;
int LoRaClass::endPacket()
// put in TX mode
writeRegister(REG_OP_MODE, MODE_LONG_RANGE_MODE | MODE_TX);
// wait for TX done
while ((readRegister(REG_IRQ_FLAGS) & IRQ_TX_DONE_MASK) == 0) {
yield();
// clear IRQ's
writeRegister(REG_IRQ_FLAGS, IRQ_TX_DONE_MASK);
return 1;
int LoRaClass::parsePacket(int size)
int packetLength = 0;
int irqFlags = readRegister(REG_IRQ_FLAGS);
if (size > 0) {
writeRegister(REG_PAYLOAD_LENGTH, size & 0xff);
} else {
// clear IRQ's
writeRegister(REG_IRQ_FLAGS, irqFlags);
if ((irqFlags & IRQ_RX_DONE_MASK) && (irqFlags & IRQ_PAYLOAD_CRC_ERROR_MASK) == 0) {
// received a packet
_packetIndex = 0;
// read packet length
if (_implicitHeaderMode) {
packetLength = readRegister(REG_PAYLOAD_LENGTH);
} else {
packetLength = readRegister(REG_RX_NB_BYTES);
// set FIFO address to current RX address
writeRegister(REG_FIFO_ADDR_PTR, readRegister(REG_FIFO_RX_CURRENT_ADDR));
idle();
} else if (readRegister(REG_OP_MODE) != (MODE_LONG_RANGE_MODE | MODE_RX_SINGLE)) {
// not currently in RX mode
// put in single RX mode
writeRegister(REG_OP_MODE, MODE_LONG_RANGE_MODE | MODE_RX_SINGLE);
return packetLength;
int LoRaClass::packetRssi()
return (readRegister(REG_PKT_RSSI_VALUE) - (_frequency < 868E6 ? 164 : 157));
float LoRaClass::packetSnr()
return ((int8_t)readRegister(REG_PKT_SNR_VALUE)) * 0.25;
size_t LoRaClass::write(uint8_t byte)
return write(&byte, sizeof(byte));
size_t LoRaClass::write(const uint8_t *buffer, size_t size)
int currentLength = readRegister(REG_PAYLOAD_LENGTH);
// check size
if ((currentLength + size) > MAX_PKT_LENGTH) {
size = MAX_PKT_LENGTH - currentLength;
// write data
for (size_t i = 0; i < size; i++) {
writeRegister(REG_FIFO, buffer[i]);
// update length
writeRegister(REG_PAYLOAD_LENGTH, currentLength + size);
return size;
int LoRaClass::available()
return (readRegister(REG_RX_NB_BYTES) - _packetIndex);
int LoRaClass::read()
if (!available()) {
return -1;
_packetIndex++;
return readRegister(REG_FIFO);
int LoRaClass::peek()
if (!available()) {
return -1;
// store current FIFO address
int currentAddress = readRegister(REG_FIFO_ADDR_PTR);
// read
uint8_t b = readRegister(REG_FIFO);
// restore FIFO address
writeRegister(REG_FIFO_ADDR_PTR, currentAddress);
return b;
void LoRaClass::flush()
void LoRaClass::onReceive(void(*callback)(int))
_onReceive = callback;
if (callback) {
writeRegister(REG_DIO_MAPPING_1, 0x00);
attachInterrupt(_dio0, LoRaClass::onDio0Rise, RISING);
} else {
detachInterrupt(_dio0);
void LoRaClass::receive(int size)
if (size > 0) {
} else {
writeRegister(REG_OP_MODE, MODE_LONG_RANGE_MODE | MODE_RX_CONTINUOUS);
void LoRaClass::idle()
writeRegister(REG_OP_MODE, MODE_LONG_RANGE_MODE | MODE_STDBY);
void LoRaClass::sleep()
writeRegister(REG_OP_MODE, MODE_LONG_RANGE_MODE | MODE_SLEEP);
void LoRaClass::setTxPower(int level, int outputPin)
if (PA_OUTPUT_RFO_PIN == outputPin) {
// RFO
if (level < 0) {
level = 0;
} else if (level > 14) {
level = 14;
writeRegister(REG_PA_CONFIG, 0x70 | level);
} else {
// PA BOOST
if (level < 2) {
level = 2;
} else if (level > 17) {
level = 17;
writeRegister(REG_PA_CONFIG, PA_BOOST | (level - 2));
void LoRaClass::setFrequency(long frequency)
_frequency = frequency;
uint64_t frf = ((uint64_t)frequency << 19) / 32000000;
writeRegister(REG_FRF_MSB, (uint8_t)(frf >> 16));
writeRegister(REG_FRF_MID, (uint8_t)(frf >> 8));
writeRegister(REG_FRF_LSB, (uint8_t)(frf >> 0));
void LoRaClass::setSpreadingFactor(int sf)
if (sf < 6) {
sf = 6;
} else if (sf > 12) {
sf = 12;
if (sf == 6) {
writeRegister(REG_DETECTION_OPTIMIZE, 0xc5);
writeRegister(REG_DETECTION_THRESHOLD, 0x0c);
} else {
writeRegister(REG_DETECTION_OPTIMIZE, 0xc3);
writeRegister(REG_DETECTION_THRESHOLD, 0x0a);
writeRegister(REG_MODEM_CONFIG_2, (readRegister(REG_MODEM_CONFIG_2) & 0x0f) | ((sf << 4) & 0xf0));
void LoRaClass::setSignalBandwidth(long sbw)
int bw;
if (sbw <= 7.8E3) {
bw = 0;
} else if (sbw <= 10.4E3) {
bw = 1;
} else if (sbw <= 15.6E3) {
bw = 2;
} else if (sbw <= 20.8E3) {
bw = 3;
} else if (sbw <= 31.25E3) {
bw = 4;
} else if (sbw <= 41.7E3) {
bw = 5;
} else if (sbw <= 62.5E3) {
bw = 6;
} else if (sbw <= 125E3) {
bw = 7;
} else if (sbw <= 250E3) {
bw = 8;
} else /*if (sbw <= 250E3)*/ {
bw = 9;
writeRegister(REG_MODEM_CONFIG_1, (readRegister(REG_MODEM_CONFIG_1) & 0x0f) | (bw << 4));
void LoRaClass::setCodingRate4(int denominator)
if (denominator < 5) {
denominator = 5;
} else if (denominator > 8) {
denominator = 8;
int cr = denominator - 4;
writeRegister(REG_MODEM_CONFIG_1, (readRegister(REG_MODEM_CONFIG_1) & 0xf1) | (cr << 1));
void LoRaClass::setPreambleLength(long length)
writeRegister(REG_PREAMBLE_MSB, (uint8_t)(length >> 8));
writeRegister(REG_PREAMBLE_LSB, (uint8_t)(length >> 0));
void LoRaClass::setSyncWord(int sw)
writeRegister(REG_SYNC_WORD, sw);
void LoRaClass::enableCrc()
writeRegister(REG_MODEM_CONFIG_2, readRegister(REG_MODEM_CONFIG_2) | 0x04);
void LoRaClass::disableCrc()
writeRegister(REG_MODEM_CONFIG_2, readRegister(REG_MODEM_CONFIG_2) & 0xfb);
byte LoRaClass::random()
return readRegister(REG_RSSI_WIDEBAND);
void LoRaClass::setPins(int ss, int reset, int dio0)
_ss = ss;
_reset = reset;
_dio0 = dio0;
void LoRaClass::setSPIFrequency(uint32_t frequency)
_spiSettings = SPISettings(frequency, MSBFIRST, SPI_MODE0);
void LoRaClass::dumpRegisters(Stream& out)
for (int i = 0; i < 128; i++) {
out.print("0x");
out.print(i, HEX);
out.print(": 0x");
out.println(readRegister(i), HEX);
void LoRaClass::explicitHeaderMode()
_implicitHeaderMode = 0;
writeRegister(REG_MODEM_CONFIG_1, readRegister(REG_MODEM_CONFIG_1) & 0xfe);
void LoRaClass::implicitHeaderMode()
_implicitHeaderMode = 1;
writeRegister(REG_MODEM_CONFIG_1, readRegister(REG_MODEM_CONFIG_1) | 0x01);
void LoRaClass::handleDio0Rise()
// clear IRQ's
if ((irqFlags & IRQ_PAYLOAD_CRC_ERROR_MASK) == 0) {
_packetIndex = 0;
int packetLength = _implicitHeaderMode ? readRegister(REG_PAYLOAD_LENGTH) : readRegister(REG_RX_NB_BYTES);
if (_onReceive) {
_onReceive(packetLength);
uint8_t LoRaClass::readRegister(uint8_t address)
return singleTransfer(address & 0x7f, 0x00);
void LoRaClass::writeRegister(uint8_t address, uint8_t value)
singleTransfer(address | 0x80, value);
uint8_t LoRaClass::singleTransfer(uint8_t address, uint8_t value)
uint8_t response;
digitalWrite(_ss, LOW);
SPI2.transfer(address);
response = SPI2.transfer(value);
SPI2.endTransaction();
return response;
void LoRaClass::onDio0Rise()
LoRa.handleDio0Rise();
LoRaClass LoRa;
