BluePill fast 10 us Timer interrupt example code needed
Posted: Thu May 11, 2023 4:59 pm
For a project in which Arduino Nano was slow, I need a very simple code example to produce a 10 us (microseconds) timer event.
I tried many code examples found here and there but I get compiler errors about missing functions and classes.
My Arduino IDE correctly compiles a simple working code but for a 1 ms resolution as the fastest possible. I can see this on PC13 with my oscilloscope.
How can I make a similar code work for a faster timer resolution ?
No matter if it is done with a libabry or just by calling HAL functions, as long as it works.
Here is a copy of the library working code. I am using the original STMicroelectronics cores definitions and HID-bootloader.
Thank you.
Roberto
Thank you.
Roberto
TimerInterruptLEDDemo.ino
For STM32 boards
Written by Khoi Hoang
Built by Khoi Hoang https://github.com/khoih-prog/STM32_TimerInterrupt
Licensed under MIT license
Now even you use all these new 16 ISR-based timers,with their maximum interval practically unlimited (limited only by
unsigned long miliseconds), you just consume only one STM32 timer and avoid conflicting with other cores' tasks.
The accuracy is nearly perfect compared to software timers. The most important feature is they're ISR-based timers
Therefore, their executions are not blocked by bad-behaving functions / tasks.
This important feature is absolutely necessary for mission-critical tasks.
Notes:
Special design is necessary to share data between interrupt code and the rest of your program.
Variables usually need to be "volatile" types. Volatile tells the compiler to avoid optimizations that assume
variable can not spontaneously change. Because your function may change variables while your program is using them,
the compiler needs this hint. But volatile alone is often not enough.
When accessing shared variables, usually interrupts must be disabled. Even with volatile,
if the interrupt changes a multi-byte variable between a sequence of instructions, it can be read incorrectly.
If your data is multiple variables, such as an array and a count, usually interrupts need to be disabled
or the entire sequence of your code which accesses the data.
#if !( defined(STM32F0) || defined(STM32F1) || defined(STM32F2) || defined(STM32F3) ||defined(STM32F4) || defined(STM32F7) || \
defined(STM32L0) || defined(STM32L1) || defined(STM32L4) || defined(STM32H7) ||defined(STM32G0) || defined(STM32G4) || \
defined(STM32WB) || defined(STM32MP1) || defined(STM32L5) )
#error This code is designed to run on STM32F/L/H/G/WB/MP1 platform! Please check your Tools->Board setting.
// These define's must be placed at the beginning before #include "STM32TimerInterrupt.h"
// _TIMERINTERRUPT_LOGLEVEL_ from 0 to 4
// Don't define _TIMERINTERRUPT_LOGLEVEL_ > 0. Only for special ISR debugging only. Can hang the system.
// Don't define TIMER_INTERRUPT_DEBUG > 2. Only for special ISR debugging only. Can hang the system.
#define TIMER_INTERRUPT_DEBUG 0
#define _TIMERINTERRUPT_LOGLEVEL_ 0
#ifndef LED_BUILTIN
#define LED_BUILTIN PB0 // Pin 33/PB0 control on-board LED_GREEN on F767ZI
#ifndef LED_BLUE
#define LED_BLUE PB7 // Pin 73/PB7 control on-board LED_BLUE on F767ZI
#ifndef LED_RED
#define LED_RED PB14 // Pin 74/PB14 control on-board LED_BLUE on F767ZI
#include "STM32_ISR_Timer.h"
//#define TIMER_INTERVAL_MS 100 orig
//#define HW_TIMER_INTERVAL_MS 50
// Depending on the board, you can select STM32 Hardware Timer from TIM1-TIM22
// For example, F767ZI can select Timer from TIM1-TIM14
// If you select a Timer not correctly, you'll get a message from ci[ompiler
// 'TIMxx' was not declared in this scope; did you mean 'TIMyy'?
// Init STM32 timer TIM1
STM32Timer ITimer(TIM1);
// Init STM32_ISR_Timer
// Each STM32_ISR_Timer can service 16 different ISR-based timers
STM32_ISR_Timer ISR_Timer;
#define TIMER_INTERVAL_0_1S 100L
#define TIMER_INTERVAL_0_5S 500L
#define TIMER_INTERVAL_1S 1000L
#define TIMER_INTERVAL_1_5S 1500L
volatile long flag , count , temp;
void TimerHandler()
ISR_Timer.run();
// In STM32, avoid doing something fancy in ISR, for example complex Serial.print with String() argument
// The pure simple Serial.prints here are just for demonstration and testing. Must be eliminate in working environment
// Or you can get this run-time error / crash
void doingSomething1()
digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
if(count++ > 500L)
temp = count;
count = 0;
flag = 1;
void doingSomething2()
digitalWrite(LED_BLUE, !digitalRead(LED_BLUE));
void doingSomething3()
digitalWrite(LED_RED, !digitalRead(LED_RED));
while (!Serial);
delay(100);
Serial.print(F("\nStarting TimerInterruptLEDDemo on ")); Serial.println(BOARD_NAME);
Serial.println(STM32_TIMER_INTERRUPT_VERSION);
Serial.print(F("CPU Frequency = ")); Serial.print(F_CPU / 1000000); Serial.println(F(" MHz"));
// Instantiate HardwareTimer object. Thanks to 'new' instanciation, HardwareTimer is not destructed when setup() function is finished.
//HardwareTimer *MyTim = new HardwareTimer(Instance);
// configure pin in output mode
pinMode(LED_BUILTIN, OUTPUT);
//pinMode(LED_BLUE, OUTPUT);
//pinMode(LED_RED, OUTPUT);
// Interval in microsecs
//if (ITimer.attachInterruptInterval(HW_TIMER_INTERVAL_MS * 1000, TimerHandler))
if (ITimer.attachInterruptInterval(15 , TimerHandler))
Serial.print(F("Starting ITimer OK, millis() = ")); Serial.println(millis());
else
Serial.println(F("Can't set ITimer. Select another freq. or timer"));
delay(2000);
// Just to demonstrate, don't use too many ISR Timers if not absolutely necessary
// You can use up to 16 timer for each ISR_Timer
ISR_Timer.setInterval(1L, doingSomething1);
//ISR_Timer.setInterval(TIMER_INTERVAL_0_5S, doingSomething1);
//ISR_Timer.setInterval(TIMER_INTERVAL_1S, doingSomething2);
//ISR_Timer.setInterval(TIMER_INTERVAL_1_5S, doingSomething3);
while(1)
if(flag)
flag = 0;
Serial.println(temp);
temp = 0L;
/* Nothing to do all is done by hardware. Even no interrupt required. */
