How to create an STM32 program using Arduino (trouble)
Posted: Fri Nov 24, 2023 4:44 am
※I am Japanese. This sentence was created using Google Translate
OS:Win11(x64)
IDE used: Arduino 2.2.1
STM32 board at hand: "STM32F103C8T6"
This is a cheap item I bought on Amazon. I think it's a compatible product. Is this the type called "Blue Pill"?
I have initialized the board using the "Flash Loader Demo" published by STM32.
I don't know how to rewrite and run the board's program from this state.
I need help. thank you.
<<<Results of verification with Arduino>>>
<<<Display when writing(The last line is garbled and unreadable)>>>
OS:Win11(x64)
FQBN: stm32duino:STM32F1:genericSTM32F103C
Using board 'genericSTM32F103C' from platform in folder: C:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2022.9.26
Using core 'maple' from platform in folder: C:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2022.9.26
loading library from d:\Developers\_VSCode\libraries\Arduino_STM32-master: invalid library: no header files found
loading library from d:\Developers\_VSCode\libraries\HoodLoader2-master: invalid library: no header files found
loading library from d:\Developers\_VSCode\libraries\USB_Digitizer_forLeonardo: invalid library: no header files found
Detecting libraries used...
C:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -fno-use-cxa-atexit -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10607 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -IC:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2022.9.26\system/libmaple -IC:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2022.9.26\system/libmaple/include -IC:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2022.9.26\system/libmaple/stm32f1/include -IC:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2022.9.26\system/libmaple/usb/stm32f1 -IC:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2022.9.26\system/libmaple/usb/usb_lib -IC:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2022.9.26\cores\maple -IC:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2022.9.26\variants\generic_stm32f103c C:\Users\kazuaki matsumoto\AppData\Local\Temp\arduino\sketches\E783984086222D8D51659A9982737D09\sketch\stm32.ino.cpp -o nul
C:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -fno-use-cxa-atexit -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10607 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -IC:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2022.9.26\system/libmaple -IC:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2022.9.26\system/libmaple/include -IC:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2022.9.26\system/libmaple/stm32f1/include -IC:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2022.9.26\system/libmaple/usb/stm32f1 -IC:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2022.9.26\system/libmaple/usb/usb_lib -IC:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2022.9.26\cores\maple -IC:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2022.9.26\variants\generic_stm32f103c C:\Users\kazuaki matsumoto\AppData\Local\Temp\arduino\sketches\E783984086222D8D51659A9982737D09\sketch\stm32.ino.cpp -o C:\Users\kazuaki matsumoto\AppData\Local\Temp\2861830982\sketch_merged.cpp
C:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\kazuaki matsumoto\AppData\Local\Temp\2861830982\sketch_merged.cpp
スケッチをコンパイルしています...
"C:\\Users\\kazuaki matsumoto\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -Wall -DDEBUG_LEVEL=DEBUG_FAULT -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -fno-use-cxa-atexit -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10607 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ "-IC:\\Users\\kazuaki matsumoto\\AppData\\Local\\Arduino15\\packages\\stm32duino\\hardware\\STM32F1\\2022.9.26\\system/libmaple" "-IC:\\Users\\kazuaki matsumoto\\AppData\\Local\\Arduino15\\packages\\stm32duino\\hardware\\STM32F1\\2022.9.26\\system/libmaple/include" "-IC:\\Users\\kazuaki matsumoto\\AppData\\Local\\Arduino15\\packages\\stm32duino\\hardware\\STM32F1\\2022.9.26\\system/libmaple/stm32f1/include" "-IC:\\Users\\kazuaki matsumoto\\AppData\\Local\\Arduino15\\packages\\stm32duino\\hardware\\STM32F1\\2022.9.26\\system/libmaple/usb/stm32f1" "-IC:\\Users\\kazuaki matsumoto\\AppData\\Local\\Arduino15\\packages\\stm32duino\\hardware\\STM32F1\\2022.9.26\\system/libmaple/usb/usb_lib" "-IC:\\Users\\kazuaki matsumoto\\AppData\\Local\\Arduino15\\packages\\stm32duino\\hardware\\STM32F1\\2022.9.26\\cores\\maple" "-IC:\\Users\\kazuaki matsumoto\\AppData\\Local\\Arduino15\\packages\\stm32duino\\hardware\\STM32F1\\2022.9.26\\variants\\generic_stm32f103c" "C:\\Users\\kazuaki matsumoto\\AppData\\Local\\Temp\\arduino\\sketches\\E783984086222D8D51659A9982737D09\\sketch\\stm32.ino.cpp" -o "C:\\Users\\kazuaki matsumoto\\AppData\\Local\\Temp\\arduino\\sketches\\E783984086222D8D51659A9982737D09\\sketch\\stm32.ino.cpp.o"
Compiling libraries...
Compiling core...
以前コンパイルされたファイルを使用中:C:\Users\kazuaki matsumoto\AppData\Local\Temp\arduino\sketches\E783984086222D8D51659A9982737D09\core\wirish\start_c.c.o
以前コンパイルされたファイルを使用中:C:\Users\kazuaki matsumoto\AppData\Local\Temp\arduino\sketches\E783984086222D8D51659A9982737D09\core\wirish\start.S.o
以前コンパイルされたファイルを使用中:C:\Users\kazuaki matsumoto\AppData\Local\Temp\arduino\sketches\E783984086222D8D51659A9982737D09\core\wirish\syscalls.c.o
以前コンパイルされたファイルを使用中:C:\Users\kazuaki matsumoto\AppData\Local\Temp\arduino\sketches\E783984086222D8D51659A9982737D09\core\board.cpp.o
以前コンパイルされたファイルを使用中:C:\Users\kazuaki matsumoto\AppData\Local\Temp\arduino\sketches\E783984086222D8D51659A9982737D09\core\wirish\boards_setup.cpp.o
以前コンパイルされたファイルを使用中:C:\Users\kazuaki matsumoto\AppData\Local\Temp\arduino\sketches\E783984086222D8D51659A9982737D09\core\wirish\boards.cpp.o
Using precompiled core: C:\Users\kazuaki matsumoto\AppData\Local\Temp\arduino\cores\a04aef0645dbcc17df720a3f52cd035c\core.a
"C:\\Users\\kazuaki matsumoto\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -Os -Wl,--gc-sections --specs=nano.specs -mcpu=cortex-m3 "-TC:\\Users\\kazuaki matsumoto\\AppData\\Local\\Arduino15\\packages\\stm32duino\\hardware\\STM32F1\\2022.9.26\\variants\\generic_stm32f103c/ld/bootloader_20.ld" "-Wl,-Map,C:\\Users\\kazuaki matsumoto\\AppData\\Local\\Temp\\arduino\\sketches\\E783984086222D8D51659A9982737D09/stm32.ino.map" "-LC:\\Users\\kazuaki matsumoto\\AppData\\Local\\Arduino15\\packages\\stm32duino\\hardware\\STM32F1\\2022.9.26\\variants\\generic_stm32f103c/ld" -o "C:\\Users\\kazuaki matsumoto\\AppData\\Local\\Temp\\arduino\\sketches\\E783984086222D8D51659A9982737D09/stm32.ino.elf" "-LC:\\Users\\kazuaki matsumoto\\AppData\\Local\\Temp\\arduino\\sketches\\E783984086222D8D51659A9982737D09" -lm -lgcc -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group "C:\\Users\\kazuaki matsumoto\\AppData\\Local\\Temp\\arduino\\sketches\\E783984086222D8D51659A9982737D09\\sketch\\stm32.ino.cpp.o" "C:\\Users\\kazuaki matsumoto\\AppData\\Local\\Temp\\arduino\\sketches\\E783984086222D8D51659A9982737D09\\core\\board.cpp.o" "C:\\Users\\kazuaki matsumoto\\AppData\\Local\\Temp\\arduino\\sketches\\E783984086222D8D51659A9982737D09\\core\\wirish\\boards.cpp.o" "C:\\Users\\kazuaki matsumoto\\AppData\\Local\\Temp\\arduino\\sketches\\E783984086222D8D51659A9982737D09\\core\\wirish\\boards_setup.cpp.o" "C:\\Users\\kazuaki matsumoto\\AppData\\Local\\Temp\\arduino\\sketches\\E783984086222D8D51659A9982737D09\\core\\wirish\\start.S.o" "C:\\Users\\kazuaki matsumoto\\AppData\\Local\\Temp\\arduino\\sketches\\E783984086222D8D51659A9982737D09\\core\\wirish\\start_c.c.o" "C:\\Users\\kazuaki matsumoto\\AppData\\Local\\Temp\\arduino\\sketches\\E783984086222D8D51659A9982737D09\\core\\wirish\\syscalls.c.o" "C:\\Users\\kazuaki matsumoto\\AppData\\Local\\Temp\\arduino\\cores\\a04aef0645dbcc17df720a3f52cd035c\\core.a" -Wl,--end-group
"C:\\Users\\kazuaki matsumoto\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-objcopy" -O binary "C:\\Users\\kazuaki matsumoto\\AppData\\Local\\Temp\\arduino\\sketches\\E783984086222D8D51659A9982737D09/stm32.ino.elf" "C:\\Users\\kazuaki matsumoto\\AppData\\Local\\Temp\\arduino\\sketches\\E783984086222D8D51659A9982737D09/stm32.ino.bin"
"C:\\Users\\kazuaki matsumoto\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-size" -A "C:\\Users\\kazuaki matsumoto\\AppData\\Local\\Temp\\arduino\\sketches\\E783984086222D8D51659A9982737D09/stm32.ino.elf"
最大65536バイトのフラッシュメモリのうち、スケッチが13844バイト(21%)を使っています。
最大20480バイトのRAMのうち、グローバル変数が2064バイト(10%)を使っていて、ローカル変数で18416バイト使うことができます。
C:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -fno-use-cxa-atexit -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8002000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10607 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -IC:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2022.9.26\system/libmaple -IC:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2022.9.26\system/libmaple/include -IC:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2022.9.26\system/libmaple/stm32f1/include -IC:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2022.9.26\system/libmaple/usb/stm32f1 -IC:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2022.9.26\system/libmaple/usb/usb_lib -IC:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2022.9.26\cores\maple -IC:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2022.9.26\variants\generic_stm32f103c C:\Users\kazuaki matsumoto\AppData\Local\Temp\arduino\sketches\E783984086222D8D51659A9982737D09\sketch\stm32.ino.cpp -o C:\Users\kazuaki matsumoto\AppData\Local\Temp\474980194\sketch_merged.cpp
C:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\kazuaki matsumoto\AppData\Local\Temp\474980194\sketch_merged.cpp
スケッチをコンパイルしています...
Compiling core...
"C:\Users\kazuaki matsumoto\AppData\Local\Arduino15\packages\stm32duino\tools\stm32tools\2022.9.26/win/maple_upload.bat" COM10 2 1EAF:0003 "C:\Users\kazuaki matsumoto\AppData\Local\Temp\arduino\sketches\E783984086222D8D51659A9982737D09/stm32.ino.bin" "C:\Program Files\Arduino\Arduino IDE\resources\app\lib\backend\resources"
'C:\Users\kazuaki' �́A�����R�}���h�܂��͊O���R�}���h�A
����\�ȃv���O�����܂��̓o�b�` �t�@�C���Ƃ��ĔF������Ă��܂���B
Failed uploading: uploading error: exit status 1
