how to enable --enable-newlib-io-long-long or _WANT_IO_LONG_LONG
danymogh
Post by danymogh »
Hello,
i need 64 bit printf support but googling says it has to be enabled explicitly using compiler option
Or a
#define _WANT_IO_LONG_LONG
in the wiki
https://github.com/stm32duino/wiki/wiki/Customize-build-options-using-build_opt.h
it says we can enable project specific compiler options but putting
gives a compile warning.
how should I do this properly ?
Answers: 91
Re: how to enable --enable-newlib-io-long-long or _WANT_IO_LONG_LONG
this options is for compiling the newlib library with the support enabled not for enable it dynamically.
https://sourceware.org/newlib/README
`configure' options
Here is a summary of the `configure' options and arguments that are
most often useful for building NEWLIB. `configure' also has several other
options not listed here.
`--enable-newlib-io-long-long'
Enable long long type support in IO functions like printf/scanf.
Disabled by default, but many hosts enable it in configure.host.
The core simply link against the newlib nano library provided with the toolchain.
You can use the Print API for Long Long:
https://github.com/stm32duino/Arduino_C ... #L101-L106
#ifdef SUPPORT_LONGLONG
    void println(int64_t, uint8_t = DEC);
    void print(int64_t, uint8_t = DEC);
    void println(uint64_t, uint8_t = DEC);
    void print(uint64_t, uint8_t = DEC);
Looking in the toolchain, it seems it is enabled, STM32\tools\xpack-arm-none-eabi-gcc\9.2.1-1.1\arm-none-eabi\include\newlib-nano\newlib.h
/* long long type support in IO functions like printf/scanf enabled */
/* #undef _WANT_IO_LONG_LONG */
danymogh
Post by danymogh »
you were right it's enabled for print but I can't get it to work for printf.
i've tried <inttypes.>c header with PRIu64 but it prints "ld". any ideas?
Answers: 91
danymogh wrote: Mon May 25, 2020 1:10 pm Hi,
No idea about this. printf is limited with nano lib so maybe there is something to enable like for float management.
