SPI partly working when using hardware, library or code CS management
mrguen
Post by mrguen »
Hello,
Maybe some of you know well the SPI?
I am trying to communicate between STM32F401RCT6 and an ADC module MCP3561.
The expected com on SPI is attached at the end of the message.
The SPI used is SPI2 with alternate pins
const byte SPI_MOSI = PC3;
const byte SPI_MISO = PC2;
const byte SPI_SCK = PB13;
const byte SPI_CS = PB12;
const uint32_t spiClk = 5000000; // or 10 MHz
byte passedValue = (MCP3561DeviceAddress << 6) & REGISTER_CONFIG1 << 2 & COMMAND_STATIC_READ_REGISTER;
1) It is partly working when using the hardware CS pin. The device answers correctly. But since the CS pin probably goes up after each transfer I can't read the data after sending a command.
SPIClass mySPI2(SPI_MOSI, SPI_MISO, SPI_SCK, SPI_CS);
SPISettings mySPIsettings = SPISettings(spiClk, MSBFIRST, SPI_MODE0);
mySPI2.begin();
mySPI2.beginTransaction(mySPIsettings);
returnedValue =  mySPI2.transfer(passedValue);
// The returned value is as expected (returning the MCP3561DeviceAddress): 00011111
returnedData =  mySPI2.transfer(0);
// Not correct all "1" . The device is supposed to send the data immediatly after receiving and answering to the command, never mind what is on MOSI.  But indeed if CS goes high MISO is supposed to return to HIGH. Or maybe I didn't catch the data ? (I did not find a shiftIn method).
mySPI2.endTransaction();
2) Using the CS management in the library: not working
SPIClass mySPI2(SPI_MOSI, SPI_MISO, SPI_SCK);
mySPI2.begin(SPI_CS);
returnedValue =  mySPI2.transfer(passedValue, SPI_CONTINUE);
// The returned value is NOT as expected - all "1"
returnedData =  mySPI2.transfer(0, SPI_LAST);
3) Managing CS pin in the code: working as with hardware management
pinMode(SPI_CS, OUTPUT);
digitalWrite(SPI_CS, HIGH);
mySPI2.begin();
digitalWrite(SPI_CS, LOW);
What might be wrong? Also I could not find a shiftIn() method.
by mrguen » Wed Sep 02, 2020 12:28 pm
The command was not correct. I can have it work when managing the CS pin in the code. I did not tested more the other two methods.
Answers: 91
Re: SPI partly working when using hardware, library or code CS management
Hi @mrguen
did you read the wiki:
https://github.com/stm32duino/wiki/wiki/API#spi
Maybe you need the SPI_CONTINUE ?
mrguen
Post by mrguen »
@fpiSTM Yes I did read the WIKI and use SPI_CONTINUE in example 2, but maybe not correctly?
Answers: 91
Well, like this I see nothing wrong. Anyway, I don't know this component (MCP3561),
is your value correct
mrguen
Post by mrguen »
@fpiSTM Yes this is a recent component (2019). So there is hardly any info available. I guess I have to analyze the signals. I will do some more test and let you know.
mrguen
Post by mrguen »
moustachedbird
Post by moustachedbird »
Sorry, I read your post and I wanted to know if you managed to program the 24 bit ADC. I'm trying to use this ADC with the ESP32 but can't get the SPI communication work.
Answers: 8
@moustachedbird , you issue is related to ESP32 and not to STM32, so you better post on ESP32 forum.
moustachedbird
@stevestrong not really, the issue is related to the 24 bit ADC, but anyway, the question was: @mrguen did you managed to program the 24 bit ADC with the STM32? Thank you :)
mrguen
Post by mrguen »
@moustachedbird
Yes I did succeed in configuring the MCP3561 and reading data on IRQ . I don' t remember exactly what was the keypoint for solving this issue. But here are the important code parts:
In a header file:
// Parameters of the Master Clock Output pin
#define MCO1_GPIO_PORT        GPIOA
#define MCO1_PIN              GPIO_PIN_8
// ADC Clock settings
const uint32_t clockFrequency = 8000000;
// MCU data ready IRQ input pin
const byte irqPin = PC6;
// These are alternate pins of SPI2
In the .ino file
// IRQ HANDLER
extern "C" {
  // handle IRQs from MCP3561 to MCI pin PC6
  void pin_IRQ() {
    //Serial.println(EXTI->PR, BIN);
    availableADCvalue = true;
    // Ajouter un compteur pour voir si on saute des IRQs et gérer l'erreur
  } // PC6_IRQ
} // extern
// Configure interrupt pin
void irqPinSetup(void) {
  pinMode(irqPin,INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(irqPin),pin_IRQ,FALLING);
  //__HAL_RCC_SYSCFG_CLK_ENABLE();
// Set up PA8 pin as MCO output to feed MCP356x external clock
void MCOSetup() {
  GPIO_InitTypeDef GPIO_InitStruct;
  __HAL_RCC_GPIOA_CLK_ENABLE();
  /* Configure the MCO1 pin in alternate function mode */
  GPIO_InitStruct.Pin = MCO1_PIN;
  GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
  GPIO_InitStruct.Alternate = GPIO_AF0_MCO;
  HAL_GPIO_Init(MCO1_GPIO_PORT, &GPIO_InitStruct);
  // Mask MCO1 and MCO1PRE[2:0] bits then Select MCO1 clock source and prescaler
   MODIFY_REG(RCC->CFGR, (RCC_CFGR_MCO1 | RCC_CFGR_MCO1PRE), (RCC_MCO1SOURCE_HSE | RCC_MCODIV_1));
// SETUP
  MCOSetup();
  // This sequence to clear the ~POR status after startup: !!! Still POR
  MCP356x.begin(SPI_CS, &mySPI2);
  MCP356x.setFrequencies(clockSourceExternal, clockFrequency, PSC_1, OSR_32);
  freqEchantillonnage = MCP356x.getDataRateClock();
  frequencyResolution = freqEchantillonnage / nbEchantillons;
  Serial.println("CONFIG2 Boost 2");
  MCP356x.writeRegister(REGISTER_CONFIG2, CONFIG2_DEFAULT | CONFIG2_BOOST_2 | CONFIG2_GAIN_1, 1);
  Serial.println("CONFIG3 Data format 32 bits with channel ID and continuous conversion");
  MCP356x.writeRegister(REGISTER_CONFIG3, CONFIG3_CONV_MODE_CONTINUOUS | CONFIG3_DATA_FORMAT_32_CHANNEL4_SGN4_24, 1);
  Serial.println("CONFIG_IRQ ");
//  MCP356x.writeRegister(REGISTER_IRQ, IRQ_MODE_IRQ | IRQ_MODE_INACTIVE_FLOAT | IRQ_FASTCMD_ENABLE);
  MCP356x.writeRegister(REGISTER_IRQ, IRQ_MODE_IRQ | IRQ_MODE_INACTIVE_HIGH | IRQ_FASTCMD_ENABLE, 1);
  Serial.println("CONFIG_MUX ");
  MCP356x.writeRegister(REGISTER_MUX, MUX_VINP_CH0 | MUX_VINM_AGND, 1);
//  MCP356x.writeRegister(REGISTER_MUX, MUX_VINP_AVDD | MUX_VINM_AGND);
  Serial.println("Start ADC");
  MCP356x.writeFastCommand(FAST_COMMAND_START);
  Serial.println("Start reading ADC");
  MCP356x.startReadADC();
  if (availableADCvalue) {
   // Fills the table
   if (cptEchantillons < nbEchantillons) {
      MCP356x.readADC(&mesADC, &channelADC); // REvoir après prise en compte du signe, ajouter 2^23
      mesuresfloat[cptEchantillons] = mesADC;
      cptEchantillons++;
    availableADCvalue = false;
