asm not working with C
Posted: Fri Oct 30, 2020 3:37 pm
Hello again.
I’ve been trying to move forward with trying to measure the time interval between 2 pulses.
Having got the asm working (the one labelled “asm1” on:
viewtopic.php?f=7&t=704&start=21
I am now trying to integrate this into C code but whatever I try, the asm stops any C code from running.
For example, this prints as expected:
This prints nothing – shows no sign of life:
I have tried putting the asm as a separate function but that does exactly the same thing.
Can anyone see what I'm doing wrong?
Thank you
Ian
void loop(); {
Serial.print something
// asm routine commented out
void loop(); {
asm
uint32_t t0,t1;
pinMode(PB4,OUTPUT);
pinMode(PB3,INPUT);
Serial.begin(250000);
void loop();
t0 = micros();
Serial.println(t0);
FastReadAsm();
t1 = micros();
Serial.println(t1);
Serial.println();
} // end loop
void FastReadAsm() {
asm (
" ldr.w r0, = #0x40010C08 \n" // GPIOB_IDR (0x40010C00 + 0x08)) Input Data Register
" ldr r2, = #0x40010C10 \n" // GPIOB_BSRR (0x40010C00 + 0x10))Bit Set Reset Register
" ldr r3, = #0x10 \n" // Bit 4 = 0b0001 0000
" ldr r4, = #0x100000 \n" // Bit 4 = 0b0001 0000 but shifted 16bits higher into
// Bit 4 = 0b0001 0000 upper (reset) register. See BSRR p173.
"again: \n"
" ldr r1, [r0] \n" // Load contents of IDR to r1
" ands r1, r1, #0x08 \n" // AND with Set flags against Bit 3 = 0b0000 1000
" beq again \n" // Branch if equal to zero (ie, no pulse there)
" str r3, [r2] \n" // Set port high
" str r4, [r2] \n" // Set port low
); // end Asm
return;
Thank you
Ian
