Red / Blue Pill Eagle Library
simonf
Post by simonf » Sun Dec 06, 2015 7:51 pm
Hi I know this isn't a Library as per this section. I have modified the maple mini library I had, I added a Blue/Red pill. Be aware I have never done this before so check your designs. I am still awaiting my first boards to arrive using this library. I did not brake out the SW-LINK pins as this would mean de-soldering the existing pins. I may add a variant later.
Please see modified download bellow
Re: Red / Blue Pill Eagle Library
Post by RogerClark » Sun Dec 06, 2015 8:25 pm
Thanks @simonf
I have used the Maple mini as a module on a PCB and it works well.
simonf
Post by simonf » Sun Dec 06, 2015 9:39 pm
RogerClark wrote:Thanks @simonf
Actually I did not do the Maple Mini I just added the BLUE PILL to the same Library. I am now struggling because the eagle lite wont let me do a 10cm x 10cm PCB. :(
I have a volume controller board and was hoping to get the receiver board on the same pcb.
Post by RogerClark » Sun Dec 06, 2015 10:06 pm
I use Eagle but I only have light, as most of the time I'm only doing small boards.
I know a lot of people have now moved to KiCad and I need to migrate to it for both commercial and non commercial work, but I find that companies seem to prefer files in Eagle format, as perhaps they can import into Altium etc
martinayotte
Post by martinayotte » Sun Dec 06, 2015 11:15 pm
Yes, that was the reason why I've switched from Eagle to Kicad more than a years ago.
If it can help, here is a online tool to migrate Eagle library to Kicad :
http://kicad.jp/Eagle2Kicad/
fredbox
Post by fredbox » Sun Dec 06, 2015 11:31 pm
I've made gerber files from Kicad and sent them to Itead. The boards turned out nicely.
Post by RogerClark » Mon Dec 07, 2015 12:32 am
I'm sure KiCad is fine.
Its just the initial learning curve... Like with everthing
simonf
Post by simonf » Mon Dec 28, 2015 10:12 pm
Hi all,
My First batch of boards made using my blue pill library arrived from Itead on xmas eve. I have just had chance to make them up. All was fine with the library but I did notice a slight problem I mislabelled PA15 as PB15 (Pin30) I have corrected it and uploaded the correct version.
The bottom board is a volume control board based on the blue pill.
maplemini.zip
New Blue Pill Library
(3.59 KiB) Downloaded 366 times
pablomuro
Post by pablomuro » Tue May 09, 2017 3:36 pm
I made an Eagle library for the BluePill, it's not perfect, but I think this can help:
https://www.4shared.com/file/SmDZ8UmPca ... ePill.html
Post by RogerClark » Wed May 10, 2017 10:04 am
@pablomuro
Thanks.
Can you zip the files and attach them to your post
