I was wanting to create a piece of code that tests the write cycle life of the flash memory in a black pill F411 using the EEPROM method. I have a friend who thinks at 10,000cycles the device will be destroyed haha. EEPROM read and write do not function correctly. I have no problem putting and getting in the setup area of the code and the data is retained over a reset. In the loop it will put and get, but my integer data is reset to -1 (unsigned go to their max value, so something is setting that area = 0-1) no matter what it was before the reset.
#include <EEPROM.h>
int f=0;
int g=0;
int eeAddress = 0; //EEPROM address to start reading from
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
EEPROM.get(0, f);
Serial.println("You just reset, here are the stored varialbes"); Serial.println(f); //This may print 'ovf, nan' if the data inside the EEPROM is not a valid float.
eeAddress += sizeof(f);
EEPROM.get(eeAddress, g);
Serial.println(g);
g += 1;
EEPROM.put(eeAddress, g);
//if this setup portion is run g will index and
//If this loop is run g and f are reset to -1 after a reset cycle
f += 2;
EEPROM.put(0,f);
Serial.println(f);
delay(60);
By default, EEPROM emulation storage correspond to the last sector/page of Flash,
and its size correspond to the size of the last sector/page.
Nevertheless it is possible to customize address and size used for EEPROM.
In this case, following switches should be defined (in variant.h or build_opt.h)
FLASH_BASE_ADDRESS
FLASH_DATA_SECTOR or FLASH_PAGE_NUMBER (depending on STM32 family used)
see example of variant implementation: https://github.com/stm32duino/Arduino_C ... 2/pull/938
