Examples
stan
Examples
Post by stan »
I want to have more examples, how to get them ?
this is what I have
and this is what I need = a long list
Re: Examples
https://www.arduino.cc/reference/en/lib ... -examples/
Roger's Core examples are installed automatically:
https://github.com/rogerclarkmelbourne/ ... s/examples
WARNING: Examples are core-dependent!
stan
Re: Examples
Post by stan »
After installing libraries from both links, list do not changed
Answers: 28
Re: Examples
Most of those examples are from installed libraries.
So look for those libraries in library manager or github.
Also on your screenshots you have 2 different cores - STM32 core (first one) and Roger's Clark core (second). Some libraries support both cores, some not, so you won't see examples from those.
stan
Re: Examples
Post by stan »
Roger's Clark core (second). =I have missed those boards, where I can find them ?
Answers: 28
Re: Examples
stan
Re: Examples
Post by stan »
Thanks I almost did,
following the last link I have long list when I using this path; arduino > hardware > library.
When I go ; files>examples the list still short
Answers: 8
Re: Examples
You have to first select the correct board ("Generic STM32F103C8 series") and then you will have a long list of examples.
stan
Re: Examples
Post by stan »
Not much to choose
list 5.png (61.4 KiB) Viewed 7332 times
I have this board installed
board 2.png (40.89 KiB) Viewed 7332 times
Answers: 92
Re: Examples
@stan
The STM32 core does not provide examples like Libmaple core because it is as much as possible compatible with Arduino API. Then it is compatible with all Arduino library following those API. So examples are the same than the library ones.
Libmaple core does not have this "full" compatibility, then several libraries have been modified including examples. That's why per default you got all those examples.
So you need to install all library you need using the Library manager or using a zip and then you will have examples.
Return to “IDE's”
