Material
Software: Stduino IDE 1.10.7
Hardware: Stduino UNO mini (STM32F103C6 main control)
Others: 7-wire OLED display (other displays such as LCD can also be used) and Dupont wire
1. Oled 7-wire line sequence
Oled 7 lines are GND, VCC, D0, D1, RES, DC, CS, here only D0 refers to Clock, D1 refers to Data, the line sequence is shown in the figure below.
2. Line sequence-specific connection
according to the following line of code to connect the line that will be ok
U8X8_SSD1306_128X64_NONAME_4W_SW_SPI u8x8(/* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
3. Download and install the library u8g24. Test the output Hello world code example, the display effect is shown in the figure above.
#include <Arduino.h>
#include <U8x8lib.h>
#ifdef U8X8_HAVE_HW_SPI
#include <SPI.h>
void setup(void)
u8x8.begin();
u8x8.setPowerSave(0);
void loop(void)
u8x8.setFont(u8x8_font_chroma48medium8_r);
u8x8.drawString(0,1,"Hello World!");
u8x8.refreshDisplay();
delay(2000);
It should be noted here that the Message Box has two select boxes that can be controlled, so here is a customization based on the pinout of the Stduino UNO mini board.
u8x8.begin(/*Select=*/ 7, /*Right/Next=*/ A1, /*Left/Prev=*/ A2, /*Up=*/ A0, /*Down=*/ A3, /*Home/Cancel=*/ 6); // Stduino
5.1 Message Box initialization display effect
The Message Box code is as follows
#include <SPI.h>
void setup(void)
void loop(void)
uint8_t r;
r = u8x8_UserInterfaceMessage(u8x8.getU8x8(), "Message", "Box", NULL, " Ok \n Cancel ");
if ( r == 0 )
u8x8.userInterfaceMessage("You pressed the", "Home/Quit", "Button", " Ok ");
else if ( r == 1 )
u8x8.userInterfaceMessage("You selected the", "Ok", "Button", " Ok ");
else if ( r == 2 )
u8x8.userInterfaceMessage("You selected the", "Cancel", "Button", " Ok ");
