DMA problem solved
What are you developing?
mlundin
Re: DMA problem solved
Post by mlundin »
Still overcomplicated, no val arrays or sin and cosines are needed
for (i = 0; i < SAMPLES; i++)
    if ( i  < SAMPLES/2)
      digitalWrite(PB8, HIGH);
    else
      digitalWrite(PB8, LOW);
    int j = i+PHASE;
    /* adjust j by a SAMPLES period to be between 0 and SAMPLES-1 */
    if (j>=SAMPLES) j-=SAMPLES;
    if ( j  < SAMPLES/2)
      digitalWrite(PB6, HIGH);
    else
      digitalWrite(PB6, LOW);
stan
Post by stan »
adjust j by a SAMPLES period = not clear.
# of SAMPLES are determining frequency of signal = period of signal. With cos there is no need for an adjustment.
stan
DMA Synchronization problem
Post by stan »
Those two squares are not synchronized with sin on PB7, I was trying to take them out from the loop but I do not succeeded.
#define SAMPLES 77
#include <libmaple/dma.h>
dma_tube_config dma_cfg, dma_cfg2;
int flag = 0;
int flag1 = 0;
int out = PB6;
int out2 = PB8;
int out1 = PB7;
int val[SAMPLES];
int val1[SAMPLES];
int16 shift = 0;
int amp = 40;//***************************************
int cnt = 0;
int time_track = 0;
float stp = 6.2831 / SAMPLES;
int ret = 17;
timer_dev *dev = PIN_MAP[out].timer_device;
uint8 cc_channel = PIN_MAP[out].timer_channel;
timer_dev *dev1 = PIN_MAP[out1].timer_device;
uint8 cc_channel1 = PIN_MAP[out1].timer_channel;
void fun()
  flag++;
void fun1()
  flag1++;
void timer_conf()
  timer_dma_set_base_addr(dev, TIMER_DMA_BASE_CCR2);
  timer_dma_set_burst_len(dev1, 1);
  timer_dma_enable_req(dev, cc_channel1);
  timer_set_reload(dev, 102);
  timer_set_prescaler(dev, 0);
  timer_dma_set_base_addr(dev1, TIMER_DMA_BASE_CCR2);
  timer_dma_enable_req(dev1, cc_channel1);
  timer_set_reload(dev1, 102);
  timer_set_prescaler(dev1, 0);
void dma_conf()
  dma_init(DMA1);
  /* T4C2 DMA C4 */
  dma_cfg.tube_dst = &(dev->regs.gen->DMAR);
  dma_cfg.tube_dst = &(dev1->regs.gen->DMAR);
  dma_cfg.tube_dst_size = DMA_SIZE_32BITS;
  dma_cfg.tube_src = val;
  dma_cfg.tube_src = val1;
  dma_cfg.tube_src_size = DMA_SIZE_32BITS;
  dma_cfg.tube_nr_xfers = SAMPLES;
  dma_cfg.tube_flags = DMA_CFG_SRC_INC | DMA_CFG_CIRC | DMA_CFG_CMPLT_IE;
  dma_cfg.tube_req_src = DMA_REQ_SRC_TIM4_CH1;
  dma_cfg.tube_req_src = DMA_REQ_SRC_TIM4_CH2;
  dma_cfg.target_data = 0;
  ret = dma_tube_cfg(DMA1, DMA_CH4, &dma_cfg);
void dma_start()
  dma_attach_interrupt(DMA1, DMA_CH4, fun);
  dma_enable(DMA1, DMA_CH4);
  timer_resume(dev1);
  dma_enable(DMA1, DMA_CH1);
  dma_enable(DMA1, DMA_CH2);
void init_wave()
  int i;
    val[i] = 40 + amp * sin(stp * i);
    val1[i] = 40 + amp * cos(stp * i);
  int i;
  pinMode(out1, PWM);
  pinMode(out, OUTPUT);
  pinMode(out2, OUTPUT);
  timer_conf();
  dma_conf();
  dma_start();
  init_wave();
  int i;
    //if ( val1[i]  > 40)
    if ( val[i]  < 40)
    else
    if ( val1[i]  > 40)
      //if ( val1[i]  > 38)
    else
stan
Re: DMA Synchronization problem
Post by stan »
I created - void init_LEDwave() - but it is not working
void init_wave()
  int i;
//311
void init_LEDwave()
  int i;
  if ( val[i]  < 40)
    else
    if ( val1[i]  > 40)
    else
It probably works as it is coded.
The question is: what do you want the function to do?
I assume the variable "i" should somehow increment...
stan
Post by stan »
This is the code with 3 outputs; PB7 = sine wave, PB6 and PB8 = square wave, sine wave is not synchronized with square waves when PB6,PB8 are in - void loop(), so I want to take them from the loop and put them outside of it.
#define SAMPLES 77
int flag = 0;
int flag1 = 0;
int out = PB6;
int out2 = PB8;
int out1 = PB7;
int val[SAMPLES];
int val1[SAMPLES];
int16 shift = 0;
int cnt = 0;
int time_track = 0;
int ret = 17;
void fun()
  flag++;
void fun1()
  flag1++;
void timer_conf()
void dma_conf()
  dma_init(DMA1);
  /* T4C2 DMA C4 */
void dma_start()
  timer_resume(dev1);
void init_wave()
  int i;
void init_LEDwave()
  int i;
  if ( val[i]  < 40)
    else
    if ( val1[i]  > 40)
    else
  int i;
  pinMode(out1, PWM);
  timer_conf();
  dma_conf();
  dma_start();
  init_wave();
  int i;
    if ( val[i]  < 40)
    else
    if ( val1[i]  > 40)
    else
nothing on PB6,PB8
stan
Post by stan »
I put PB6,PB8 inside - void init_wave() - I got only sine
void init_wave()
  int i;
      if ( val[i]  < 40)
    else
    if ( val1[i]  > 40)
    else
Return to “Projects”
