Page 3 of 3
Re: DMA problem solved
Posted: Sat Nov 21, 2020 5:11 pm
by mlundin
Still overcomplicated, no val arrays or sin and cosines are needed
for (i = 0; i < SAMPLES; i++)
if ( i < SAMPLES/2)
digitalWrite(PB8, HIGH);
else
digitalWrite(PB8, LOW);
int j = i+PHASE;
/* adjust j by a SAMPLES period to be between 0 and SAMPLES-1 */
if (j>=SAMPLES) j-=SAMPLES;
if ( j < SAMPLES/2)
digitalWrite(PB6, HIGH);
else
digitalWrite(PB6, LOW);
Posted: Sat Nov 21, 2020 6:00 pm
by stan
adjust j by a SAMPLES period = not clear.
# of SAMPLES are determining frequency of signal = period of signal. With cos there is no need for an adjustment.
DMA Synchronization problem
Posted: Sat Nov 21, 2020 6:52 pm
by stan
Those two squares are not synchronized with sin on PB7, I was trying to take them out from the loop but I do not succeeded.
#define SAMPLES 77
#include <libmaple/dma.h>
dma_tube_config dma_cfg, dma_cfg2;
int flag = 0;
int flag1 = 0;
int out = PB6;
int out2 = PB8;
int out1 = PB7;
int val[SAMPLES];
int val1[SAMPLES];
int16 shift = 0;
int amp = 40;//***************************************
int cnt = 0;
int time_track = 0;
float stp = 6.2831 / SAMPLES;
int ret = 17;
timer_dev *dev = PIN_MAP[out].timer_device;
uint8 cc_channel = PIN_MAP[out].timer_channel;
timer_dev *dev1 = PIN_MAP[out1].timer_device;
uint8 cc_channel1 = PIN_MAP[out1].timer_channel;
void fun()
flag++;
void fun1()
flag1++;
void timer_conf()
timer_dma_set_base_addr(dev, TIMER_DMA_BASE_CCR2);
timer_dma_set_burst_len(dev1, 1);
timer_dma_enable_req(dev, cc_channel1);
timer_set_reload(dev, 102);
timer_set_prescaler(dev, 0);
timer_dma_set_base_addr(dev1, TIMER_DMA_BASE_CCR2);
timer_dma_enable_req(dev1, cc_channel1);
timer_set_reload(dev1, 102);
timer_set_prescaler(dev1, 0);
void dma_conf()
dma_init(DMA1);
/* T4C2 DMA C4 */
dma_cfg.tube_dst = &(dev->regs.gen->DMAR);
dma_cfg.tube_dst = &(dev1->regs.gen->DMAR);
dma_cfg.tube_dst_size = DMA_SIZE_32BITS;
dma_cfg.tube_src = val;
dma_cfg.tube_src = val1;
dma_cfg.tube_src_size = DMA_SIZE_32BITS;
dma_cfg.tube_nr_xfers = SAMPLES;
dma_cfg.tube_flags = DMA_CFG_SRC_INC | DMA_CFG_CIRC | DMA_CFG_CMPLT_IE;
dma_cfg.tube_req_src = DMA_REQ_SRC_TIM4_CH1;
dma_cfg.tube_req_src = DMA_REQ_SRC_TIM4_CH2;
dma_cfg.target_data = 0;
ret = dma_tube_cfg(DMA1, DMA_CH4, &dma_cfg);
void dma_start()
dma_attach_interrupt(DMA1, DMA_CH4, fun);
dma_enable(DMA1, DMA_CH4);
timer_resume(dev1);
dma_enable(DMA1, DMA_CH1);
dma_enable(DMA1, DMA_CH2);
void init_wave()
int i;
val[i] = 40 + amp * sin(stp * i);
val1[i] = 40 + amp * cos(stp * i);
int i;
pinMode(out1, PWM);
pinMode(out, OUTPUT);
pinMode(out2, OUTPUT);
timer_conf();
dma_conf();
dma_start();
init_wave();
int i;
//if ( val1[i] > 40)
if ( val[i] < 40)
else
if ( val1[i] > 40)
//if ( val1[i] > 38)
else
Re: DMA Synchronization problem
Posted: Sun Nov 22, 2020 12:02 pm
by stan
I created - void init_LEDwave() - but it is not working
void init_wave()
int i;
//311
void init_LEDwave()
int i;
if ( val[i] < 40)
else
if ( val1[i] > 40)
else
Posted: Sun Nov 22, 2020 1:18 pm
by stevestrong
It probably works as it is coded.
The question is: what do you want the function to do?
I assume the variable "i" should somehow increment...
Posted: Sun Nov 22, 2020 2:41 pm
by stan
This is the code with 3 outputs; PB7 = sine wave, PB6 and PB8 = square wave, sine wave is not synchronized with square waves when PB6,PB8 are in - void loop(), so I want to take them from the loop and put them outside of it.
#define SAMPLES 77
int flag = 0;
int flag1 = 0;
int out = PB6;
int out2 = PB8;
int out1 = PB7;
int val[SAMPLES];
int val1[SAMPLES];
int16 shift = 0;
int cnt = 0;
int time_track = 0;
int ret = 17;
void fun()
flag++;
void fun1()
flag1++;
void timer_conf()
void dma_conf()
dma_init(DMA1);
/* T4C2 DMA C4 */
void dma_start()
timer_resume(dev1);
void init_wave()
int i;
void init_LEDwave()
int i;
if ( val[i] < 40)
else
if ( val1[i] > 40)
else
int i;
pinMode(out1, PWM);
timer_conf();
dma_conf();
dma_start();
init_wave();
int i;
if ( val[i] < 40)
else
if ( val1[i] > 40)
else
nothing on PB6,PB8
Posted: Sun Nov 22, 2020 2:52 pm
by stan
I put PB6,PB8 inside - void init_wave() - I got only sine
void init_wave()
int i;
if ( val[i] < 40)
else
if ( val1[i] > 40)
else
