Nucleo F411RE and serial
Kenjutsu
Post by Kenjutsu »
Hello everyone
I dusted off my Nucleo F411RE board today to get it working again with STM32 Core. I can upload via the onboard ST-Link (after the firmware update) and Mass Storage. My question is where does Serial.print output go? There is a serial port (/dev/cu.XXXX) but no output appears there.
What am I missing? ;)
by Kenjutsu » Wed Jun 03, 2020 4:01 pm
fpiSTM wrote: Wed Jun 03, 2020 2:14 pm So simply set USB support to None and then this should be ok.
Thank you, that did the trick 8-)
Pieter
OSX: 11.6.8
Arduino IDE: 1.8.19
PlatformIO: 6.1.4
STM32 Core: 2.3.0
Get a $5 off coupon on your first purchase at Kaiweets
Kaiweets Affordable & Smart Electrical Testing Tools
Re: Nucleo F411RE and serial
Hi kenjutsu
I don't remember which dev format it is on Mac, anyway it is simple to find which one it is.
List all /dev/* with the board disconnected then with the board connected and check the diff.
The port should also be listed in Arduino, if not there is a issue.
Which Arduino IDE version you used ? Did you select the right baudrate?
Kenjutsu
Post by Kenjutsu »
Thank you for the reply,
Under /dev are two entries related to the F411RE:
  • /dev/tty.usbmodemFA13123
  • /dev/cu.usbmodemFA13123
Under Arduino -> Tools I have the following settings:
/dev/cu.usbmodemFA13123 is automatically selected and is also the only option available. The same happens under CoolTerm.
I create a new Blink example with the following in setup():
and in loop():
Serial.println("Toggle LED");
I upload to the board and start the Serial Monitor and nothing is displayed. The same for CoolTerm. The connection to the serial port is fine. The ST-Link V2.1 is at firmware V2J37M26
Pieter
OSX: 11.6.8
Arduino IDE: 1.8.19
PlatformIO: 6.1.4
STM32 Core: 2.3.0
The Nucleo F411RE has no real USB connector.
The USB connector available is for the STLink and the VCP com port created forward the data of a real USART.
Kenjutsu
Post by Kenjutsu »
Pieter
OSX: 11.6.8
Arduino IDE: 1.8.19
PlatformIO: 6.1.4
STM32 Core: 2.3.0
Sleipnir164
Post by Sleipnir164 »
I've got the same problem about not seeing anything in the serial com port.
Setting USB support to None didn't help me.
I'm using a stm32 nucleo f411re and the latest version of ardiuno IDE on windows.
Anyone willing to help ?
