Re: Stm32f070 programming
Posted: Tue Sep 22, 2020 2:17 pm
hello again, i fixed my codes and ran it. But I'm having a problem. When I install a program by activating USB CDC ,program running but I cannot connect to ST-LINK UTILITY. I can only connect after boot mode. But when the USB CDC is off and after installing the program I am connecting to ST-LINK UTILITY.
Also, when USB CDC is on and optimized Fast (-O1), I connect to ST-LINK UTILITY but USB is not active.
The new variant is as follows:
What do these mean?
ST-LINK UTILITY output:
# FIREPLACE board
GenF0.menu.pnum.FIREPLACE=Fireplace v1
GenF0.menu.pnum.FIREPLACE.upload.maximum_size=131072
GenF0.menu.pnum.FIREPLACE.upload.maximum_data_size=20480
GenF0.menu.pnum.FIREPLACE.build.mcu=cortex-m0
GenF0.menu.pnum.FIREPLACE.build.board=FIREPLACE
GenF0.menu.pnum.FIREPLACE.build.series=STM32F0xx
GenF0.menu.pnum.FIREPLACE.build.product_line=STM32F070xB
GenF0.menu.pnum.FIREPLACE.build.variant=FIREPLACE_R
GenF0.menu.pnum.FIREPLACE.build.cmsis_lib_gcc=arm_cortexM0l_math
RCC_OscInitTypeDef RCC_OscInitStruct;
RCC_ClkInitTypeDef RCC_ClkInitStruct;
RCC_PeriphCLKInitTypeDef PeriphClkInit;
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI | RCC_OSCILLATORTYPE_HSI14
| RCC_OSCILLATORTYPE_LSI | RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSI14State = RCC_HSI14_ON;
RCC_OscInitStruct.HSICalibrationValue = 16;
RCC_OscInitStruct.HSI14CalibrationValue = 16;
RCC_OscInitStruct.LSIState = RCC_LSI_ON;
RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL6;
RCC_OscInitStruct.PLL.PREDIV = RCC_PREDIV_DIV1;
HAL_RCC_OscConfig(&RCC_OscInitStruct);
| RCC_CLOCKTYPE_PCLK1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK) {
_Error_Handler(__FILE__, __LINE__);
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USB | RCC_PERIPHCLK_USART1
| RCC_PERIPHCLK_I2C1;
PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK1;
PeriphClkInit.I2c1ClockSelection = RCC_I2C1CLKSOURCE_HSI;
PeriphClkInit.UsbClockSelection = RCC_USBCLKSOURCE_PLL;
if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK) {
17:19:41 : ST-LINK SN : 7A91080032124647524B4E00
17:19:41 : ST-LINK Firmware version : V2J34S7
17:19:41 : Connected via SWD.
17:19:41 : SWD Frequency = 4,0 MHz.
17:19:41 : Connection mode : HotPlug.
17:19:41 : Debug in Low Power mode enabled.
17:19:42 : Device ID:0x448
17:19:42 : Device flash Size : 128KBytes
17:19:42 : Device family :STM32F072xx/F078xx
17:19:49 : [Blink.ino.hex] opened successfully.
17:19:49 : [Blink.ino.hex] checksum : 0x001BBA1B
17:19:52 : Memory programmed in 1s and 578ms.
17:19:53 : Disconnected from device.
17:19:53 : Connection to device is lost: check power supply and debug connection.
17:19:53 : If the target is in low power mode, please enable "Debug in Low Power mode" option from Target->settings menu.
