Page 2 of 3
Re: charging lipo batteries
Posted: Sun Oct 18, 2020 8:59 pm
by GonzoG
ag123 wrote: ↑Sun Oct 18, 2020 12:53 pm
average voltage of 4.2v is maintained.
No. It's not average 4.2V. It's
maximum 4.2V.
And with capacitor you'll definitely get more.
Posted: Sun Oct 18, 2020 11:31 pm
by mrburnette
cjcj1949 wrote: ↑Sun Oct 18, 2020 1:26 pm
They can be made to burn if abused.
Another plus for LiFePO4. Hopefully, the energy density for these low-risk cells will continue to improve.
Posted: Tue Oct 20, 2020 2:54 am
thanks all, i did a little google (re)search on the topic and stumbled into many articles
apparently the most common charging strategies for lithium ion batteries is constant current below 4.2v and constant voltage 4.2v at the end.
there are quite many articles around the internet
https://en.wikipedia.org/wiki/Lithium-i ... _discharge
https://www.electronics-notes.com/artic ... arging.php
https://www.eetimes.com/current-voltage ... -charging/#
https://www.eetimes.com/current-voltage ... ng-part-2/
apparently a large influence factor on the durability and hence safety of the battery is the temperature !
https://www.nature.com/articles/srep12967
charging at 1 C is actually pretty high it translates to 1 ampere for 1 hour for a 1 AH battery.
i think more commonly currents are lower for the average usb connection more like 250-500 mA (there are many better chargers these days that can supply in the ranges of amps, most likely some buck converters) and for small solar cells / panel getting 100-500 mA is good on a sunny day.
hence with solar cells we'd get an coincidental 'constant current' charging simply due to the limited solar power that can be delivered
what would be somewhat curious is can pwm mimic the constant current, constant voltage charging that's typically done with possibly analog circuits.
if that pwm CC CV charging is possible, stm32 can be its own li-ion battery charger with just a single mosfet say from a usb power source. i think the main aim of the CC charging phase is to limit the heating of the battery, that can be done by simply reducing the pwm duty cycle
apparently, this isn't really all that new, some have been there done that
https://www.embedded.com/managing-devic ... odulation/
https://www.microfarad.de/li-charger/
interestingly found an app note from ST
in the proposed circuit, it is basically a buck converter, driven by the mcu using pwm, but it is quite interesting
there is actually some incentive for doing all these, the mcu is both the charger and columb counter, it manages the complete state of the battery and can give indications of the battery state and even estimated power remaining and estimated charging time, while still doing other things
Posted: Wed Jun 16, 2021 8:58 am
by ClarkWu
Hi...In the event that you have a charger that shows battery inner obstruction, watch that first prior to doing anything to the batteries, they should be 1-4 milliOhm.
Whenever left depleted, set charge to in a real sense the most minimal charge rate and stream them for two to four hours, check the batteries. In a ton of cases you may need to stream them for some time. When you get them to capacity voltage, release them to cutoff and afterward endeavor 1c equilibrium charge rate.
Whenever left completely energized, again check interior opposition. In the event that alright, release them at 1 amp and continue to release them at 1 amp until cutoff, check battery, assuming alright, run a Storage charge the battery, then, at that point release at 2-3 amps, check interior opposition and last completely balance charge and trial, continue to screen the battery.
https://www.7pcb.com/
Posted: Sat Jun 19, 2021 12:47 am
by mrburnette
NOT AN ADVERTISEMENT OR SALES RECOMMENDATION.
But, I have been testing out this charging board and it appears to work well:
https://www.amazon.com/dp/B089Q1HBXL?ps ... ct_details
Posted: Sat Jun 19, 2021 6:30 am
@ray
nice, i'd guess the prevalence and low costs of these li-po charging modules these days gives little incentive to do 'custom' li po charging, they are nearly priced 5 pieces to 1 stm32f103 blue pill board. but i'm just thinking a lot of times the timers on stm32 are simply 'idle' they could be used for instance to charge a lipo battery via pwm
a note about those 'mobile power bank' styled 5v battery chargers though i noted some of them requires that you draw rather significant milliamps of current or it'd shutdown the port. i've once tried using a 'power bank' which apparently doesn't power up a blue pill board, but if i connect a higher load such as a 100 ohm resistance across vcc - gnd power comes on.
Posted: Sat Jun 19, 2021 11:42 pm
by mrburnette
ag123 wrote: ↑Sat Jun 19, 2021 6:30 am
Yes, I noted the same behavior.
I use LiFePO4 chemistry for "lite" uC loads and the charging requirements of those cells are very simple.
Posted: Mon Oct 18, 2021 10:08 am
by jacobli
I was using an
LCD that came with a lithium battery, and I was wondering if this lithium battery was rechargeable?
- IMG_5184.JPG (87.24 KiB) Viewed 3834 times
Posted: Mon Oct 18, 2021 10:41 pm
by GonzoG
No. It's a primary battery.
But those are used mainly as a backup batteries or in devices that barely draw any current and last quite some time.
Posted: Sat Oct 23, 2021 4:43 pm
oh that one normally powers VBAT - i.e. keeps your RTC running, as that normally consumes micro amps. But it is hardly the re-chargable sort and runs out of power shortly if you use it as your main power supply.
