![Image](https://raw.githubusercontent.com/GleissonAlmeida/example-codes/main/download_from_github/bim.png)
STM32 Library paths included in flash memory
After compiling the code, when opening the binary it is possible to see the path of some libraries, how can I avoid including this information in the binary? - STM32F103 nucleo ![Image](https://raw.githubusercontent.com/GleissonAlmeida/example-codes/main/download_from_github/bim.png)
Re: STM32 Library paths included in flash memory
maybe it is debug info? try playing with the -g (debug) flags,
hello.
how could i do this?
if you are using the (arduino) IDE, check in the menu for debug options
no promises though, it is likely some symbols remains
Which options are set in the Arduino menu?
