Does anybody know what is wrong with either of the SD card and ArduCAM libraries for STM32?
I have provided different chip select pins on my hardware and the same SPI connections to the SD card socket and ArduCAM. Both work fine alone with Nucleo 64.
If I have both, I cannot take any photo unless I run the ArduCAM setup every time that I take the photo which is not good!
I cannot keep the SD card file open if I want to take a photo and record data on SD! If I close the file, I can take the photo. However, the photo data is not correctly recorded!
This is the link for ArduCAM:
I used to have a simple SD card library included Arduino. Do I need to replace it with another library if I use STM32 with Arduino IDE?
Any help is appreciated
