Sloeber IDE runs with core 1.7 but not with 1.8
kurtow187
Post by kurtow187 »
Hello,
I tested the Sloeber IDE (based on Eclipse).
It runs very well for me and I can compile a quite complex sketch. Also the upload to Bluepill is running.
But only with the 1.7 core.
When I try to use the stmduino 1.8 core, there are a lot of errors.
Even a 'naked' sketch (only setup() and loop() ) without any code raises compiling errors.
Maybe that this is a sloeber issue... may it be caused by the update from CMSIS_5 to 5.6.0 ??
Has anyone some experience with sloeber?
regards
Kurtow187
Answers: 53
Re: Sloeber IDE runs with core 1.7 but not with 1.8
I don't think it is linked to CMSIS.
If you properly installed the core this should be fine.
I don't have anymore eclipse installed with Sloeber as now I'm using VSCode + Arduino plugin.
What I guess is that Sloeber doesn't execute properly a prebuilt recipe.
The main change in the 1.8.0 is that all HAL and BSP has been moved to a built-in library to be able to remove whole-archive usage and avoid weak functions issues but this implies to include this builtin library to be able to build.
This is what is made by the prebuild recipe:
https://github.com/stm32duino/Arduino_C ... #L117-L120
So try to include manually this library:
#include <SrcWrapper.h>
But this is only a guess as you don't post any log...
luca_stm32
Post by luca_stm32 »
Hi everybody.
I had the same problem with 1.8 core version.
With the fpiSTM suggestion Sloeber can compile.
Luca
Answers: 53
Thanks luca_stm32 for the feedback.
This means Sloeber does not handle properly the prebuild recipe from the platform.txt.
https://github.com/Sloeber/arduino-ecli ... ssues/1143
Return to “IDE's”
