Using Arduino_Core_STM32 with git repository
Posted: Sat Sep 12, 2020 3:13 am
I followed the instruction provided in the wiki:
https://github.com/stm32duino/wiki/wiki ... repository
But it does not seem to be able to find the PATH of the toolchain. The error is as follows:
I am using STM32F072 Discovery board and would like to add/modify the code. If I modified the compiler.path in platform.txt, then it works just fine, like this:
I am wondering if this is something missing in the documentation, or there is a bug of determining the correct PATH in Arduino IDE.
The problem continues... I had to modify also the path for the programming tools, etc. Is there a way to fix this? Any comments?
Detecting libraries used...
/bin/arm-none-eabi-g++ -mcpu=cortex-m0 -mthumb @/tmp/arduino_build_533985/sketch/build_opt.h -c -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -fno-use-cxa-atexit -I/home/ubuntu/arduino-1.8.13/examples/01.Basics/Blink -I/home/ubuntu/Arduino/hardware/STM32/stm32/cores/arduino/avr -I/home/ubuntu/Arduino/hardware/STM32/stm32/cores/arduino/stm32 -I/home/ubuntu/Arduino/hardware/STM32/stm32/cores/arduino/stm32/LL -I/home/ubuntu/Arduino/hardware/STM32/stm32/cores/arduino/stm32/usb -I/home/ubuntu/Arduino/hardware/STM32/stm32/cores/arduino/stm32/OpenAMP -I/home/ubuntu/Arduino/hardware/STM32/stm32/cores/arduino/stm32/usb/hid -I/home/ubuntu/Arduino/hardware/STM32/stm32/cores/arduino/stm32/usb/cdc -I/home/ubuntu/Arduino/hardware/STM32/stm32/system/Drivers/STM32F0xx_HAL_Driver/Inc -I/home/ubuntu/Arduino/hardware/STM32/stm32/system/Drivers/STM32F0xx_HAL_Driver/Src -I/home/ubuntu/Arduino/hardware/STM32/stm32/system/STM32F0xx -I/home/ubuntu/Arduino/hardware/STM32/stm32/system/Middlewares/ST/STM32_USB_Device_Library/Core/Inc -I/home/ubuntu/Arduino/hardware/STM32/stm32/system/Middlewares/ST/STM32_USB_Device_Library/Core/Src -I/home/ubuntu/Arduino/hardware/STM32/stm32/system/Middlewares/OpenAMP -I/home/ubuntu/Arduino/hardware/STM32/stm32/system/Middlewares/OpenAMP/open-amp/lib/include -I/home/ubuntu/Arduino/hardware/STM32/stm32/system/Middlewares/OpenAMP/libmetal/lib/include -I/home/ubuntu/Arduino/hardware/STM32/stm32/system/Middlewares/OpenAMP/virtual_driver -w -x c++ -E -CC -DSTM32F0xx -DARDUINO=10813 -DARDUINO_DISCO_F072RB -DARDUINO_ARCH_STM32 "-DBOARD_NAME=\"DISCO_F072RB\"" -DSTM32F072xB -DUSBCON -DUSBD_VID=0 -DUSBD_PID=0 -DHAL_PCD_MODULE_ENABLED -DUSBD_USE_CDC -DHAL_UART_MODULE_ENABLED -DHWSERIAL_NONE -I/home/ubuntu/.arduino15/packages/STM32/tools/CMSIS/5.5.1/CMSIS/Core/Include/ -I/home/ubuntu/Arduino/hardware/STM32/stm32/system/Drivers/CMSIS/Device/ST/STM32F0xx/Include/ -I/home/ubuntu/Arduino/hardware/STM32/stm32/system/Drivers/CMSIS/Device/ST/STM32F0xx/Source/Templates/gcc/ -I/home/ubuntu/.arduino15/packages/STM32/tools/CMSIS/5.5.1/CMSIS/DSP/Include -I/home/ubuntu/Arduino/hardware/STM32/stm32/cores/arduino -I/home/ubuntu/Arduino/hardware/STM32/stm32/variants/DISCO_F072RB /tmp/arduino_build_533985/sketch/Blink.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
fork/exec /bin/arm-none-eabi-g++: no such file or directory
Error compiling for board Discovery.
#compiler.path={runtime.tools.xpack-arm-none-eabi-gcc-9.3.1-1.2.path}/bin/
compiler.path=/home/ubuntu/.arduino15/packages/STM32/tools/xpack-arm-none-eabi-gcc/9.2.1-1.1/bin/
