Unable to compile with Sloeber and Core 1.9.0
Posted: Wed Jan 06, 2021 8:04 pm
Hi there,
I have problems compiling projects with the Sloeber IDE (latest nightly) and 1.9.0 Core. It seems that it compiles ok, but when it comes to linkage the combiner can't find the precompiled files:
Compiler output is:
The makefile fails at this line:
With 1.7.0 it works flawlessly. It sounds similar to this and this issue, but as far as I understood the issues with SrcWrapper should be gone with the latest Sloeber nightly. I'm not sure if it's a Sloeber related problem, but since 1.9.0 is already around for some time that must be a known problem.
Can someone tell me more about that problem?
Thanks!
Compiler output is:
'Starting combiner'
"D:\Programme\Sloeber\arduinoPlugin\packages\STM32\tools\xpack-arm-none-eabi-gcc\9.2.1-1.1/bin/arm-none-eabi-gcc" -mcpu=cortex-m3 -mthumb -Os --specs=nano.specs -u _printf_float -Wl,--defsym=LD_FLASH_OFFSET=0 -Wl,--defsym=LD_MAX_SIZE=65536 -Wl,--defsym=LD_MAX_DATA_SIZE=20480 -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--entry=Reset_Handler -Wl,--unresolved-symbols=report-all -Wl,--warn-common "-Wl,--default-script=D:\Programme\Sloeber\arduinoPlugin\packages\STM32\hardware\stm32\1.9.0\variants\PILL_F103XX/ldscript.ld" "-Wl,--script=D:\Programme\Sloeber\arduinoPlugin\packages\STM32\hardware\stm32\1.9.0\system/ldscript.ld" "-Wl,-Map,E:\OneDrive\Technik\_programmierung\sloeber-workspace\BlinkTest\hwdebug/BlinkTest.map" "-LD:\Programme\Sloeber\arduinoPlugin\packages\STM32\tools\CMSIS\5.5.1/CMSIS/DSP/Lib/GCC/" -larm_cortexM3l_math -o "E:\OneDrive\Technik\_programmierung\sloeber-workspace\BlinkTest\hwdebug/BlinkTest.elf" "-LE:\OneDrive\Technik\_programmierung\sloeber-workspace\BlinkTest\hwdebug" -Wl,--start-group .\sloeber.ino.cpp.o .\libraries\SrcWrapper\src\stm32\PortNames.c.o .\libraries\SrcWrapper\src\stm32\analog.cpp.o .\libraries\SrcWrapper\src\stm32\bootloader.c.o .\libraries\SrcWrapper\src\stm32\clock.c.o .\libraries\SrcWrapper\src\stm32\core_callback.c.o .\libraries\SrcWrapper\src\stm32\dwt.c.o .\libraries\SrcWrapper\src\stm32\hw_config.c.o .\libraries\SrcWrapper\src\stm32\interrupt.cpp.o .\libraries\SrcWrapper\src\stm32\lock_resource.c.o .\libraries\SrcWrapper\src\stm32\low_power.c.o .\libraries\SrcWrapper\src\stm32\pinmap.c.o .\libraries\SrcWrapper\src\stm32\rtc.c.o .\libraries\SrcWrapper\src\stm32\stm32_def.c.o .\libraries\SrcWrapper\src\stm32\stm32_eeprom.c.o .\libraries\SrcWrapper\src\stm32\system_stm32yyxx.c.o .\libraries\SrcWrapper\src\stm32\timer.c.o .\libraries\SrcWrapper\src\stm32\uart.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_adc.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_bdma.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_comp.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_cordic.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_crc.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_crs.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_dac.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_delayblock.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_dma.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_dma2d.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_exti.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_fmac.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_fmc.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_fsmc.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_gpio.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_hrtim.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_i2c.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_lptim.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_lpuart.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_mdma.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_opamp.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_pka.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_pwr.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_rcc.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_rng.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_rtc.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_sdmmc.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_spi.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_swpmi.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_tim.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_ucpd.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_usart.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_usb.c.o .\libraries\SrcWrapper\src\LL\stm32yyxx_ll_utils.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_adc.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_adc_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_can.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_cec.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_comp.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_comp_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_cordic.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_cortex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_crc.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_crc_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_cryp.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_cryp_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_dac.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_dac_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_dcmi.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_dcmi_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_dfsdm.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_dfsdm_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_dma.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_dma2d.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_dma_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_dsi.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_dts.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_eth.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_eth_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_exti.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_fdcan.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_firewall.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_flash.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_flash_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_flash_ramfunc.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_fmac.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_fmpi2c.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_fmpi2c_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_gfxmmu.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_gpio.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_gpio_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_hash.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_hash_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_hcd.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_hrtim.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_hsem.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_i2c.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_i2c_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_i2s.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_i2s_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_ipcc.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_irda.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_iwdg.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_jpeg.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_lcd.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_lptim.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_ltdc.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_ltdc_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_mdios.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_mdma.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_mmc.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_mmc_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_nand.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_nor.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_opamp.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_opamp_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_ospi.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_otfdec.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_pccard.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_pcd.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_pcd_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_pka.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_pssi.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_pwr.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_pwr_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_qspi.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_ramecc.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_rcc.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_rcc_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_rng.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_rng_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_rtc.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_rtc_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_sai.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_sai_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_sd.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_sd_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_sdadc.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_sdram.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_smartcard.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_smartcard_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_smbus.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_spdifrx.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_spi.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_spi_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_sram.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_swpmi.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_tim.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_tim_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_tsc.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_uart.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_uart_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_usart.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_usart_ex.c.o .\libraries\SrcWrapper\src\HAL\stm32yyxx_hal_wwdg.c.o .\libraries\SrcWrapper\src\syscalls.c.o .\core\variant\PeripheralPins.c.o .\core\variant\variant.cpp.o E:\OneDrive\Technik\_programmierung\sloeber-workspace\BlinkTest\hwdebug/arduino.ar -lc -Wl,--end-group -lm -lgcc -lstdc++
arm-none-eabi-gcc: error: .\libraries\SrcWrappr\src\HAL\stm32yyxx_hal_sdram.c.o: No such file or directory
makefile:96: recipe for target 'BlinkTest.elf' failed
make: *** [BlinkTest.elf] Error 1
@echo 'Starting combiner'
"D:\Programme\Sloeber\arduinoPlugin\packages\STM32\tools\xpack-arm-none-eabi-gcc\9.2.1-1.1/bin/arm-none-eabi-gcc" -mcpu=cortex-m3 -mthumb -Os --specs=nano.specs -u _printf_float -Wl,--defsym=LD_FLASH_OFFSET=0 -Wl,--defsym=LD_MAX_SIZE=65536 -Wl,--defsym=LD_MAX_DATA_SIZE=20480 -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--entry=Reset_Handler -Wl,--unresolved-symbols=report-all -Wl,--warn-common "-Wl,--default-script=D:\Programme\Sloeber\arduinoPlugin\packages\STM32\hardware\stm32\1.9.0\variants\PILL_F103XX/ldscript.ld" "-Wl,--script=D:\Programme\Sloeber\arduinoPlugin\packages\STM32\hardware\stm32\1.9.0\system/ldscript.ld" "-Wl,-Map,E:\OneDrive\Technik\_programmierung\sloeber-workspace\BlinkTest\hwdebug/BlinkTest.map" "-LD:\Programme\Sloeber\arduinoPlugin\packages\STM32\tools\CMSIS\5.5.1/CMSIS/DSP/Lib/GCC/" -larm_cortexM3l_math -o "E:\OneDrive\Technik\_programmierung\sloeber-workspace\BlinkTest\hwdebug/BlinkTest.elf" "-LE:\OneDrive\Technik\_programmierung\sloeber-workspace\BlinkTest\hwdebug" -Wl,--start-group $(LINK_OBJ) E:\OneDrive\Technik\_programmierung\sloeber-workspace\BlinkTest\hwdebug/arduino.ar -lc -Wl,--end-group -lm -lgcc -lstdc++
Thanks!
