stm32 uploading with stlink not uploading
Posted: Fri May 08, 2020 9:57 am
by jonghaboy
hi
i am trying to upload a simple blink code to a bluepill using arduino ide and a st link.
i am currently following this video step by step
https://youtu.be/zUk0lN1oEwQ?t=382
I am having trouble with one computer while another computer works fine and is uploading code.
i have done all the steps exactly like the second half of the video where it explains how to use stlink
i have looked at the two computers and they give me different messages after uploading
can anyone fix this problem?
the computer that doesn't work gives me a message like this after uploading
C:\Users\User\Desktop\Blink>rem @echo off
C:\Users\User\Desktop\Blink>rem: Note C:\Users\User\AppData\Local\Arduino15\packages\stm32duino\tools\stm32tools\2020.4.23\win\ get path of this batch file
C:\Users\User\Desktop\Blink>rem: Need to change drive if My Documents is on a drive other than C:
C:\Users\User\Desktop\Blink>set driverLetter=C:\Users\User\AppData\Local\Arduino15\packages\stm32duino\tools\stm32tools\2020.4.23\win\
C:\Users\User\Desktop\Blink>C:
C:\Users\User\Desktop\Blink>cd C:\Users\User\AppData\Local\Arduino15\packages\stm32duino\tools\stm32tools\2020.4.23\win\
C:\Users\User\AppData\Local\Arduino15\packages\stm32duino\tools\stm32tools\2020.4.23\win>rem: the two line below are needed to fix path issues with incorrect slashes before the bin file name
C:\Users\User\AppData\Local\Arduino15\packages\stm32duino\tools\stm32tools\2020.4.23\win>set str=C:\Users\User\AppData\Local\Temp\arduino_build_756723/Blink.ino.bin
C:\Users\User\AppData\Local\Arduino15\packages\stm32duino\tools\stm32tools\2020.4.23\win>set str=C:\Users\User\AppData\Local\Temp\arduino_build_756723\Blink.ino.bin
C:\Users\User\AppData\Local\Arduino15\packages\stm32duino\tools\stm32tools\2020.4.23\win>rem: ------------- use STLINK CLI
C:\Users\User\AppData\Local\Arduino15\packages\stm32duino\tools\stm32tools\2020.4.23\win>stlink\ST-LINK_CLI.exe -c SWD -P C:\Users\User\AppData\Local\Temp\arduino_build_756723\Blink.ino.bin 0x8000000 -Rst -Run -NoPrompt
C:\Users\User\AppData\Local\Arduino15\packages\stm32duino\tools\stm32tools\2020.4.23\win>rem: Using the open source texane-stlink instead of the proprietary STM stlink exe
C:\Users\User\AppData\Local\Arduino15\packages\stm32duino\tools\stm32tools\2020.4.23\win>rem:texane-stlink\st-flash.exe write C:\Users\User\AppData\Local\Temp\arduino_build_756723\Blink.ino.bin 0x8000000
while the computer that works gives me this
C:\Program Files (x86)\Arduino>rem @echo off
C:\Program Files (x86)\Arduino>rem: Note C:\Users\jongha\AppData\Local\Arduino15\packages\stm32duino\tools\stm32tools\2020.3.13\win\ get path of this batch file
C:\Program Files (x86)\Arduino>rem: Need to change drive if My Documents is on a drive other than C:
C:\Program Files (x86)\Arduino>set driverLetter=C:\Users\jongha\AppData\Local\Arduino15\packages\stm32duino\tools\stm32tools\2020.3.13\win\
C:\Program Files (x86)\Arduino>C:
C:\Program Files (x86)\Arduino>cd C:\Users\jongha\AppData\Local\Arduino15\packages\stm32duino\tools\stm32tools\2020.3.13\win\
C:\Users\jongha\AppData\Local\Arduino15\packages\stm32duino\tools\stm32tools\2020.3.13\win>rem: the two line below are needed to fix path issues with incorrect slashes before the bin file name
C:\Users\jongha\AppData\Local\Arduino15\packages\stm32duino\tools\stm32tools\2020.3.13\win>set str=C:\Users\jongha\AppData\Local\Temp\arduino_build_303798/Blink.ino.bin
C:\Users\jongha\AppData\Local\Arduino15\packages\stm32duino\tools\stm32tools\2020.3.13\win>set str=C:\Users\jongha\AppData\Local\Temp\arduino_build_303798\Blink.ino.bin
C:\Users\jongha\AppData\Local\Arduino15\packages\stm32duino\tools\stm32tools\2020.3.13\win>rem: ------------- use STLINK CLI
C:\Users\jongha\AppData\Local\Arduino15\packages\stm32duino\tools\stm32tools\2020.3.13\win>stlink\ST-LINK_CLI.exe -c SWD -P C:\Users\jongha\AppData\Local\Temp\arduino_build_303798\Blink.ino.bin 0x8000000 -Rst -Run -NoPrompt
STM32 ST-LINK CLI v3.3.0.0
STM32 ST-LINK Command Line Interface
ST-LINK SN: Old ST-LINK firmware/ST-LINK already used
ST-LINK Firmware version: V2J17S4 (Need Update)
Connected via SWD.
Target voltage = 3.3 V
Connection mode: Normal
Reset mode: Software reset
Device ID: 0x410
Device flash Size: 64 Kbytes
Device family: STM32F10xx Medium-density
Loading file...
Flash Programming:
  File : C:\Users\jongha\AppData\Local\Temp\arduino_build_303798\Blink.ino.bin
  Address : 0x08000000
Memory programming...
�������������������������������������������������� 0%
 0%���������������������������� 56%���������������������� 100%
Memory programmed in 1s and 360ms.
Programming Complete.
MCU Reset.
Application started.
C:\Users\jongha\AppData\Local\Arduino15\packages\stm32duino\tools\stm32tools\2020.3.13\win>rem: Using the open source texane-stlink instead of the proprietary STM stlink exe
C:\Users\jongha\AppData\Local\Arduino15\packages\stm32duino\tools\stm32tools\2020.3.13\win>rem:texane-stlink\st-flash.exe write C:\Users\jongha\AppData\Local\Temp\arduino_build_303798\Blink.ino.bin 0x8000000
Re: stm32 uploading with stlink not uploading
Posted: Fri May 08, 2020 12:36 pm
by stevestrong
You have to install the STLink driver onto the non-working PC.
Posted: Mon May 11, 2020 1:29 am
by jonghaboy
i did insall the stlink driver just like the one that works
would there be any other reason?
Posted: Mon May 11, 2020 5:36 am
by stas2z
check C:\Users\User\AppData\Local\Arduino15\packages\stm32duino\tools\stm32tools\2020.4.23\win folder and ensure it contains stlink subfolder with ST-LINK_CLI.exe inside
Posted: Wed May 13, 2020 1:38 am
by jonghaboy
ok it did not contain those files
so i copied the files from the working comp to the not working comp
but the results were the same
what todo?
Posted: Wed May 13, 2020 2:08 am
by jonghaboy
i erased everything with a clean slate and started over, checked the AppDAta folder to see the files installed, tried again, but still didn't work
Posted: Tue May 19, 2020 3:43 am
by jonghaboy
to anyone with similar issues,
i checked
folder and ensure it contains stlink subfolder with ST-LINK_CLI.exe.
i double clicked on ST-LINK_CLI.exe and got som weird directX errors.
i updated directX and reinstalled visual C++ updates on windows and tried clicking on ST-LINK_CLI.exe.
what you should get is a cmd window with a bunch of lines showing you what commands you can use.
problem fixed.
