Timer starts and then freezes.
Fabaum
Post by Fabaum »
Hello friends,
I am modifying an example program for testing the TIM2 general purpose timer of the STM32L476RG board.
Just to check operation, LED1 is activated periodically by the timer. At the same time, I use an oscilloscope connected to pin PA5, which corresponds to LED1.
With the fixed timing value, the program works perfectly.
However, after implementing a potentiometer to change the timing, I start to have problems.
LED1 just starts to switch, but then it freezes ...
The program is compiled without errors, I do not understand why it is not working in this configuration with the potentiometer.
Here is the program:
#define pin  PA5
TIM_TypeDef *Instance = TIM2;
int potenciometro;
int tempo=10000;
  pinMode(pin, OUTPUT);
  MyTim->setMode(2, TIMER_OUTPUT_COMPARE);
  MyTim->setOverflow(tempo, MICROSEC_FORMAT);
  MyTim->attachInterrupt(Update_IT_callback);
  MyTim->resume();
  potenciometro = analogRead(PA1);
  tempo=map(potenciometro,10,1023,100000,100);
void Update_IT_callback(HardwareTimer*)
  MyTim->pause();
  digitalWrite(pin, !digitalRead(pin));
  MyTim->resume();
By eliminating the line "MyTim->setOverflow(tempo, MICROSEC_FORMAT);" inside void loop (), the program works perfectly with fixed timing.
I don't want to make a PWM, I'm just testing the functionality of timer 2 with a potentiometer.
What am I doing wrong?
ABOSTM
Re: Timer starts and then freezes.
Post by ABOSTM »
Hi @Fabaum,
line below looks strange to me:
What happends if potencimetro is below 10 ?
Also the 3rd argument should be greater than the 4th one.
So can you try with this :
tempo=map(potenciometro, 0,1024, 100, 100000);
Can you also print the values of potencimetro and tempo to check is there is no abnormal values.
Fabaum
Post by Fabaum »
Hi ABOSTM,
I am viewing the potentiometer values on an LCD display. Even with the potentiometer at its minimum value, the board's analog input reads 10 bytes, certainly due to some residual resistance. So, stating 10 as the minimum value, I establish that this is my zero point.
The fact that I am reversing the output signals means that the more the potentiometer is turned, the less time I must reload on timer2, and the faster it will overflow.
I found out what was wrong: the reload of timer2 must occur during the interruption, that is, within the "void Update_IT_callback (HardwareTimer *)" subroutine, before "MyTim-> resume ();".
Thanks for your help!
Bakisha
Answers: 4
Post by Bakisha »
I don't know for sure if integer in Arduino IDE is 16bit or 32bit signed value, but setOverflow accept 32bit unsigned value.
Try with:
unsigned int tempo=10000;
or better:
uint32_t tempo = 10000;
Also, i don't think you need to pause timer at all.
Just to be sure [mention]Fabaum[/mention]
STM32 works with 3.3V not 5V. So ADC range is for 0-3.3V.
ABOSTM
Post by ABOSTM »
From my point of view there is no reason to call pause() and resume() within Update_IT_callback()
Fabaum
Post by Fabaum »
In fact, fpiSTM, I was using 5V on the pot when I realized that reading through the analog port stopped at a certain point. Fortunately, it did not damage the microcontroller!
Bakisha and ABOSTM, I will test the routine without pausing the timer, thanks for the suggestions!
Fortunately several STM32 pins are 5V tolerant. They are referenced in the datasheet.
kishor2stm32
Post by kishor2stm32 »
Hello everyone!!
I started coding my Discovery B-L475IoT01A board using arduino IDE.
I did basic examples & Wifi Related one.
Now i want to add timer event in my code for time sequenced operation.
I don't know how to use timer functions, Can anyone has done earlier, will help me for this.
regards,
kishor Potdar.
stas2z
Answers: 8
Post by stas2z »
Return to “STM32L4 based boards”
