Timer not enabled when using only CC Interrupts
fjulian79
Post by fjulian79 »
Hi ..
I'm using a Nucleo F446Re with lib version 2.1:
There is an issue when just using timer capture/compare interrupts without a overflow interrupt. In this case the used timer will not be started. I see no good reason why this should not be supported as you can use 4 independent interrupts in this case by using just one timer.
Example code to reproduce this ..
pTimer->setPrescaleFactor(prescaler);
// using TIMER_DISABLED here as suggested in HardwareTimer.h line 39 when only interested in the interrupt
pTimer->setMode(ch, TIMER_DISABLED);
pTimer->setOverflow(UINT16_MAX);
pTimer->attachInterrupt(ch, cc_callback);
pTimer->setCaptureCompare(ch, value);
pTimer->setCount(0);
pTimer->resume();
A quick fix ..
void HardwareTimer::resume(void)
  // Clear flag and ennable IT
  if (callbacks[0]) {
    __HAL_TIM_CLEAR_FLAG(&(_timerObj.handle), TIM_FLAG_UPDATE);
    __HAL_TIM_ENABLE_IT(&(_timerObj.handle), TIM_IT_UPDATE);
    // Start timer in Time base mode. Required when there is no channel used but only update interrupt.
    // Never reached if no ov callback has been registered. Timer is not started elsewhere when TIMER_DISABLED has been used not he channels.
    //HAL_TIM_Base_Start(&(_timerObj.handle));
  // Resume all channels
  resumeChannel(1);
  resumeChannel(2);
  resumeChannel(3);
  resumeChannel(4);
I have already filed a issue on github, see https://github.com/stm32duino/Arduino_C ... ssues/1544
Br J.
Return to “PR's bugs and enhancements”
