I am using the stm32duino core by stmelectronics version 2.4.0 and I want to know whether the I2c wire object declared using the wire.h library run on hardware i2c or softi2c.
Hardware : stm32f405rgtxx
Pins for i2c : PB10 , PB11
hard i2c vs soft i2c
Re: hard i2c vs soft i2c
It uses hardware.
Is the code So smart to switch to hardware i2c if we use the i2c capable pins and then switch to software i2c when we use any other pins.
Also I am actually working on a Firmware for the F4 boards and in that i have to interface a dps310 barometer over i2c and requesting 25 bytes of data and waiting for it to come takes a lot of time(2000us ) Is there a better way in which I could request the data and while the data is incoming I could do something else?
link to my whole code: https://github.com/anshchawla521/DIY_FC
void getAbosluteAltitudeFromBaro()
/* Description : This functions Gets one altitude data from baro*/
if (barometer_status != ACTIVE)
return;
Wire2.beginTransmission(0x76);
Wire2.write(0x08);
if (Wire2.endTransmission() != 0)
barometer_status = NOTPRESENT;
return;
Wire2.requestFrom(0x76, 1);
uint8_t meas_cfg;
while (Wire2.available() > 0)
meas_cfg = Wire2.read();
if ((meas_cfg & 0b10000000) == 0b10000000)
// read cofficients
Wire2.write(0x10);
Wire2.endTransmission();
Wire2.requestFrom(0x76, 18); // request pressure and temp data
byte i = 0;
while (Wire2.available())
if (i >= 18)
// error
Serial.println("ERRor in getting baro reading");
break;
buffer_cofficients[i++] = Wire2.read();
c0 = (buffer_cofficients[0] & 0x80 ? 0xFF : 0) << 12 | buffer_cofficients[0] << 4 | buffer_cofficients[1] >> 4; // was 12 bit so had to extend msb manually
c1 = (buffer_cofficients[1] & 0x08 ? 0xFF : 0) << 12 | (buffer_cofficients[1] & 0x0f) << 8 | buffer_cofficients[2];
c00 = (buffer_cofficients[3] & 0x80 ? 0xFFFF : 0) << 20 | buffer_cofficients[3] << 12 | buffer_cofficients[4] << 4 | buffer_cofficients[5] >> 4; // was 20 bit so had to extend msb manually
c10 = (buffer_cofficients[5] & 0x08 ? 0xFFFF : 0) << 20 | (buffer_cofficients[5] & 0x0f) << 16 | buffer_cofficients[6] << 8 | buffer_cofficients[7];
c01 = buffer_cofficients[8] << 8 | buffer_cofficients[9];
c11 = buffer_cofficients[10] << 8 | buffer_cofficients[11];
c20 = buffer_cofficients[12] << 8 | buffer_cofficients[13];
c21 = buffer_cofficients[14] << 8 | buffer_cofficients[15];
c30 = buffer_cofficients[16] << 8 | buffer_cofficients[17];
if ((meas_cfg & 0b00010000) == 0b00010000)
// new pressure data available;
// read temperature then only
Wire2.write(0x00);
Wire2.requestFrom(0x76, 6); // request pressure and temp data
byte i = 0;
if (i >= 6)
// error
break;
pressure = int32_t((buffer_cofficients[0] & 0x80 ? 0xFF : 0) << 24 | (buffer_cofficients[0] << 16 | buffer_cofficients[1] << 8 | buffer_cofficients[2])); // was 24 bit so had to add msb // also it is unsigned so before converting to float have to convert to int
temperature = int32_t((buffer_cofficients[3] & 0x80 ? 0xFF : 0) << 24 | (buffer_cofficients[3] << 16 | buffer_cofficients[4] << 8 | buffer_cofficients[5]));
pressure = pressure / float(K_pressure);
temperature = temperature / float(K_temperature);
pressure = double(c00) + pressure * (double(c10) + pressure * (double(c20) + pressure * double(c30))) + temperature * double(c01) + temperature * pressure * (double(c11) + pressure * double(c21));
temperature = double(c0) * 0.5 + double(c1) * temperature;
altitude_from_baro = 44330 * (1.0 - pow(pressure / 100.0 / 1013.25, 0.1903));
// get data from baro
