ESP8266_AT_WebServer library now supports STM32 boards using ESP8266 AT-command shields
khoih-prog
Post by khoih-prog »
New Version v1.0.3
1. Add support to STM32 (STM32,F0,F1, F2, F3, F4, F7, etc) boards
New Version v1.0.2
1. Add support to SAM DUE, SAMD (ZERO, MKR, NANO_33_IOT, M0, M0 Pro, AdaFruit CIRCUITPLAYGROUND_EXPRESS, etc.) boards
This is simple yet complete WebServer library for AVR, Teensy, SAM DUE, SAMD, STM32, etc. boards running ESP8266 AT-command shields. The functions are similar and compatible to ESP8266/ESP32 WebServer libraries to make life much easier to port sketches from ESP8266/ESP32.
The library supports
1. WiFi Client, STA and AP mode
2. TCP Server and Client
3. UDP Server and Client
4. HTTP Server and Client
5. HTTP GET and POST requests, provides argument parsing, handles one client at a time.
Library is based on and modified from:
1. Ivan Grokhotkov's ESP8266WebServer
2. bportaluri's WiFiEsp library
The ESP8266_AT_Web_Server class found in ESP8266_AT_Web_Server.h header, is a simple web server that knows how to handle HTTP requests such as GET and POST and can only support one simultaneous client.
Sample Code
#define DEBUG_ESP8266_AT_WEBSERVER_PORT Serial
#if    ( defined(ARDUINO_SAM_DUE) || defined(ARDUINO_SAMD_ZERO) || defined(ARDUINO_SAMD_MKR1000) || defined(ARDUINO_SAMD_MKRWIFI1010) \
      || defined(ARDUINO_SAMD_NANO_33_IOT) || defined(ARDUINO_SAMD_MKRFox1200) || defined(ARDUINO_SAMD_MKRWAN1300) || defined(ARDUINO_SAMD_MKRWAN1310) \
      || defined(ARDUINO_SAMD_MKRGSM1400) || defined(ARDUINO_SAMD_MKRNB1500) || defined(ARDUINO_SAMD_MKRVIDOR4000) || defined(__SAMD21G18A__) \
      || defined(ARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS) || defined(__SAM3X8E__) || defined(__CPU_ARC__) )
  #if defined(ESP8266_AT_USE_SAMD)
    #undef ESP8266_AT_USE_SAMD
  #define ESP8266_AT_USE_SAMD      true
#if ( defined(STM32F0) || defined(STM32F1) || defined(STM32F2) || defined(STM32F3)  ||defined(STM32F4) || defined(STM32F7) )
  #if defined(ESP8266_AT_USE_STM32)
    #undef ESP8266_AT_USE_STM32
  #define ESP8266_AT_USE_STM32      true
#ifdef CORE_TEENSY
  // For Teensy 4.0
  #define EspSerial Serial2   //Serial2, Pin RX2 : 7, TX2 : 8
  #if defined(__IMXRT1062__)
  #define BOARD_TYPE      "TEENSY 4.0"
  #elif ( defined(__MKL26Z64__) || defined(ARDUINO_ARCH_AVR) )
  #define BOARD_TYPE      "TEENSY LC or 2.0"
  #else
  #define BOARD_TYPE      "TEENSY 3.X"
#elif defined(ESP8266_AT_USE_SAMD)
// For SAMD
  #define EspSerial Serial1
  #if defined(ARDUINO_SAMD_ZERO)
    #define BOARD_TYPE      "SAMD Zero"
  #elif defined(ARDUINO_SAMD_MKR1000)
    #define BOARD_TYPE      "SAMD MKR1000"
  #elif defined(ARDUINO_SAMD_MKRWIFI1010)
    #define BOARD_TYPE      "SAMD MKRWIFI1010"
  #elif defined(ARDUINO_SAMD_NANO_33_IOT)
    #define BOARD_TYPE      "SAMD NANO_33_IOT"
  #elif defined(ARDUINO_SAMD_MKRFox1200)
    #define BOARD_TYPE      "SAMD MKRFox1200"
  #elif ( defined(ARDUINO_SAMD_MKRWAN1300) || defined(ARDUINO_SAMD_MKRWAN1310) )
    #define BOARD_TYPE      "SAMD MKRWAN13X0"
  #elif defined(ARDUINO_SAMD_MKRGSM1400)
    #define BOARD_TYPE      "SAMD MKRGSM1400"
  #elif defined(ARDUINO_SAMD_MKRNB1500)
    #define BOARD_TYPE      "SAMD MKRNB1500"
  #elif defined(ARDUINO_SAMD_MKRVIDOR4000)
    #define BOARD_TYPE      "SAMD MKRVIDOR4000"
  #elif defined(ARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS)
    #define BOARD_TYPE      "SAMD ARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS"
  #elif ( defined(__SAM3X8E__) || (__SAM3X8E__) || (__CPU_ARC__) )
    #define BOARD_TYPE      "SAMD Board"
  #else
    #define BOARD_TYPE      "SAMD Unknown"
#elif defined(ESP8266_AT_USE_STM32)
// For STM32
  #if defined(STM32F0)
    #define BOARD_TYPE  "STM32F0"
  #elif defined(STM32F1)
    #define BOARD_TYPE  "STM32F1"
  #elif defined(STM32F2)
    #define BOARD_TYPE  "STM32F2"
  #elif defined(STM32F3)
    #define BOARD_TYPE  "STM32F3"
  #elif defined(STM32F4)
    #define BOARD_TYPE  "STM32F4"
  #elif defined(STM32F7)
    #define BOARD_TYPE  "STM32F7"
  #else
    #warning STM32 unknown board selected
    #define BOARD_TYPE  "STM32 Unknown"
#else
// For Mega
#define EspSerial Serial3
#define BOARD_TYPE      "AVR Mega"
#include <ESP8266_AT_WebServer.h>
char ssid[] = "****";        // your network SSID (name)
char pass[] = "****";        // your network password
int status = WL_IDLE_STATUS;     // the Wifi radio's status
int reqCount = 0;                // number of requests received
ESP8266_AT_WebServer server(80);
const int led = 13;
void handleRoot()
  server.send(200, "text/plain", "Hello from ESP8266_AT_WebServer!");
void handleNotFound()
  String message = "File Not Found\n\n";
  message += "URI: ";
  message += server.uri();
  message += "\nMethod: ";
  message += (server.method() == HTTP_GET)?"GET":"POST";
  message += "\nArguments: ";
  message += server.args();
  message += "\n";
  for (uint8_t i=0; i<server.args(); i++)
    message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
  server.send(404, "text/plain", message);
  digitalWrite(led, 0);
void setup(void)
  // Open serial communications and wait for port to open:
  // initialize serial for ESP module
  EspSerial.begin(115200);
  // initialize ESP module
  WiFi.init(&EspSerial);
  Serial.println("\nStarting HelloServer on " + String(BOARD_TYPE));
  // check for the presence of the shield
  if (WiFi.status() == WL_NO_SHIELD)
    Serial.println(F("WiFi shield not present"));
    // don't continue
    while (true);
  // attempt to connect to WiFi network
  while ( status != WL_CONNECTED)
    Serial.print(F("Connecting to WPA SSID: "));
    Serial.println(ssid);
    // Connect to WPA/WPA2 network
    status = WiFi.begin(ssid, pass);
  server.begin();
  Serial.print("WebServer is @ ");
  Serial.println(WiFi.localIP());
  server.on("/", handleRoot);
  server.on("/inline", []()
    server.send(200, "text/plain", "This works as well");
  server.onNotFound(handleNotFound);
  server.begin();
  Serial.print(F("HTTP server started @ "));
void loop(void)
  server.handleClient();
