AsyncDNSServer_STM32 for STM32 using builtin LAN8742A Ethernet
Posted: Tue Sep 08, 2020 10:23 pm
AsyncDNSServer_STM32 Library
Why do we need this Async AsyncDNSServer_STM32 Library
- Using asynchronous network means that you can handle more than one connection at the same time
- You are called once the packet is ready
- After connecting to a UDP server as an Async Client, you are immediately ready to handle other connections while the Client is taking care of receiving the UDP responding packets in the background.
- You are not required to check in a tight loop() the arrival of the UDP responding packets to process them.
- Speed is OMG
Initial Releases v1.0.0
1. Initial coding to port Develo's ESPAsyncDNSServer Library to STM32 boards using built-in LAN8742A Ethernet. More supports will be added gradually later, such as other Ethernet / WiFi shields.
2. Add more examples.
3. Add debugging features.
Currently Supported Boards
1. Nucleo-144 (F429ZI, F746ZG, F756ZG, F767ZI)
2. Discovery STM32F746G-DISCOVERY
3. Any STM32 boards with enough flash/memory and already configured to run LAN8742A Ethernet.
Sample Code
This is the AsyncDNSServer_STM32 example
- Speed is OMG
Sample Code
Currently support
1) STM32 boards with built-in Ethernet (to use USE_BUILTIN_ETHERNET = true) such as :
- Nucleo-144 (F429ZI, F767ZI)
- STM32 boards (STM32F/L/H/G/WB/MP1) with 32K+ Flash, with Built-in Ethernet,
- See How To Use Built-in Ethernet at (https://github.com/khoih-prog/EthernetWebServer_STM32/issues/1)
#include "defines.h"
#include <AsyncDNSServer_STM32.h>
#include <AsyncWebServer_STM32.h>
const byte DNS_PORT = 53;
IPAddress apIP;
AsyncDNSServer dnsServer;
AsyncWebServer server(80);
void handleNotFound(AsyncWebServerRequest *request)
String message = "Hello World!\n\n";
message += "URI: ";
message += request->url();
request->send(200, "text/plain", message);
Serial.println("\nStart AsyncDNSServer_STM32 on " + String(BOARD_NAME));
// start the ethernet connection and the server
// Use random mac
// Use Static IP
Ethernet.begin(mac[index]);;
apIP = Ethernet.localIP();
// modify TTL associated with the domain name (in seconds)
// default is 60 seconds
dnsServer.setTTL(300);
// set which return code will be used for all other domains
// (e.g. sending ServerFailure instead of NonExistentDomain will reduce number of queries
// sent by clients). Default is AsyncDNSReplyCode::NonExistentDomain
dnsServer.setErrorReplyCode(AsyncDNSReplyCode::ServerFailure);
// start DNS server for a specific domain name
dnsServer.start(DNS_PORT, "*", apIP);
server.begin();
Serial.print(F("HTTP EthernetWebServer is @ IP : "));
Serial.println(apIP);
