STM32_TimerInterrupt Library. Now supporting L5 and H7
khoih-prog
Post by khoih-prog »
This library enables you to use Interrupt from Hardware Timers on an STM32-based board. It now enables you to use up to 16 different ISR-based timers, while actually consuming only 1 Hardware Timer. Timers' interval is very long (ulong millisecs). The most important feature is they're ISR-based timers. Therefore, their executions are not blocked by bad-behaving functions or tasks. This important feature is absolutely necessary for mission-critical tasks.
Why do we need this STM32_TimerInterrupt Library
Imagine you have a system with a mission-critical function, measuring water level and control the sump pump or doing something much more important. You normally use asoftware timer to poll, or even place the function in loop(). But what if another function is blocking the loop() or setup().
So your function might not be executed, and the result would be disastrous.
You'd prefer to have your function called, no matter what happening with other functions (busy loop, bug, etc.).
The correct choice is to use a Hardware Timer with Interrupt to call your function.
These hardware timers, using interrupt, still work even if other functions are blocking. Moreover, they are much more precise (certainly depending on clock frequency accuracy) than other software timers using millis() or micros(). That's necessary if you need to measure some data requiring better accuracy.
Functions using normal software timers, relying on loop() and calling millis(), won't work if the loop() or setup() is blocked by certain operation. For example, certain function is blocking while it's connecting to WiFi or some services.
The catch is your function is now part of an ISR (Interrupt Service Routine), must be lean and mean, and follow certain rules. More to read on:
HOWTO Attach Interrupt
Important Notes:
1. Inside the ISR function, delay() won’t work and the value returned by millis() will not increment. Serial data received while in the ISR function may be lost. You should declare as volatile any variables that you modify within the attached function.
2. Typically global variables are used to pass data between an ISR and the main program. To make sure variables shared between an ISR and the main program are updated correctly, declare them as volatile.
Releases v1.0.0
1. Permit up to 16 super-long-time, super-accurate ISR-based timers to avoid being blocked
2. Using cpp code besides Impl.h code to use if Multiple-Definition linker error.
Supported Boards
1. STM32 boards with built-in Ethernet LAN8742A such as :
- Nucleo-144 (F429ZI, F767ZI)
- Discovery (STM32F746G-DISCOVERY)
- All STM32 boards (STM32F/L/H/G/WB/MP1) with 32K+ Flash, with Built-in Ethernet
2. STM32F/L/H/G/WB/MP1 boards (with 32+K Flash) running W5x00 or ENC28J60 shields)
- Nucleo-144
- Nucleo-64
- Discovery
- Generic STM32F0, STM32F1, STM32F2, STM32F3, STM32F4, STM32F7 (with 64+K Flash): x8 and up
- STM32L0, STM32L1, STM32L4
- STM32G0, STM32G4
- STM32H7
- STM32WB
- STM32MP1
- LoRa boards
- 3-D printer boards
- Generic Flight Controllers
- Midatronics boards
Examples:
1. Argument_None
2. ISR_RPM_Measure
3. ISR_Timer_Complex
4. RPM_Measure
5. SwitchDebounce
6. TimerInterruptTest
7. TimerInterruptLEDDemo
Debug Termimal Output Samples
1. The following is the sample terminal output when running example ISR_Timer_Complex on STM32F7 Nucleo-144 F767ZI using Built-in LAN8742A Ethernet and STM32Ethernet Library to demonstrate the accuracy of ISR Hardware Timer, especially when system is very busy. The ISR timer is programmed for 2s, is activated exactly after 2.000s !!!
While software timer, programmed for 2s, is activated after 9.782s !!!. Then in loop(), it's also activated every 3s.
Starting ISR_Timer_Complex on NUCLEO_F767ZI
Version : 1.0.0
STM32TimerInterrupt: Timer Input Freq (Hz) = 216000000, _fre = 1000000.00, _count = 50000
Starting  ITimer OK, millis() = 6
[9] MAC:FE-E1-88-EC-DD-95
2s: Delta ms = 2000
2s: Delta ms = 2000
[6626] IP:192.168.2.116
[6626]
    ___  __          __
   / _ )/ /_ _____  / /__
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v0.6.1 on STM32 NUCLEO_F767ZI
[6636] BlynkArduinoClient.connect: Connecting to account.duckdns.org:8080
[6721] Ready (ping: 6ms).
IP = 192.168.2.116
2s: Delta ms = 2000
blynkDoingSomething2s: Delta programmed ms = 2000, actual = 9782
2s: Delta ms = 2000
5s: Delta ms = 5000
2s: Delta ms = 2000
blynkDoingSomething2s: Delta programmed ms = 2000, actual = 3000
2s: Delta ms = 2000
5s: Delta ms = 5000
2s: Delta ms = 2000
2s: Delta ms = 2000
2s: Delta ms = 2000
5s: Delta ms = 5000
2s: Delta ms = 2000
11s: Delta ms = 11000
2s: Delta ms = 2000
5s: Delta ms = 5000
2s: Delta ms = 2000
2s: Delta ms = 2000
2s: Delta ms = 2000
5s: Delta ms = 5000
2s: Delta ms = 2000
2s: Delta ms = 2000
5s: Delta ms = 5000
2s: Delta ms = 2000
2. The following is the sample terminal output when running exampleTimerInterruptTest on STM32F7 Nucleo-144 F767ZI to demonstrate how to start/stop Hardware Timers.
Starting TimerInterruptTest on NUCLEO_F767ZI
Version : 1.0.0
STM32TimerInterrupt: Timer Input Freq (Hz) = 216000000, _fre = 1000000.00, _count = 1000000
Starting  ITimer0 OK, millis() = 108
STM32TimerInterrupt: Timer Input Freq (Hz) = 108000000, _fre = 1000000.00, _count = 3000000
Starting  ITimer1 OK, millis() = 119
Stop ITimer0, millis() = 5001
Start ITimer0, millis() = 10002
Stop ITimer1, millis() = 15001
Stop ITimer0, millis() = 15003
Start ITimer0, millis() = 20004
Stop ITimer0, millis() = 25005
Start ITimer1, millis() = 30002
Start ITimer0, millis() = 30006
Stop ITimer0, millis() = 35007
Start ITimer0, millis() = 40008
Stop ITimer1, millis() = 45003
Stop ITimer0, millis() = 45009
Start ITimer0, millis() = 50010
Stop ITimer0, millis() = 55011
Start ITimer1, millis() = 60004
Start ITimer0, millis() = 60012
Stop ITimer0, millis() = 65013
Start ITimer0, millis() = 70014
Stop ITimer1, millis() = 75005
Stop ITimer0, millis() = 75015
Start ITimer0, millis() = 80016
Stop ITimer0, millis() = 85017
Start ITimer1, millis() = 90006
Start ITimer0, millis() = 90018
Stop ITimer0, millis() = 95019
Start ITimer0, millis() = 100020
zoomx
Re: STM32_TimerInterrupt Library
Post by zoomx »
+1!!
tschrama
Post by tschrama »
+1
khoih-prog
Releases v1.2.1
1. Add support to STM32L5 (NUCLEO_L552ZE_Q)
2. Verify OK with STM32H7 (NUCLEO_H743ZI2)
Releases v1.2.0
1. Add better debug feature.
2. Optimize code and examples to reduce RAM usage
3. Add Table of Contents
