EthernetWebServer_SSL_STM32 Library now supports TLS/SSL Client and LAN8720
khoih-prog
Post by khoih-prog »
Why do we need this EthernetWebServer_SSL_STM32 Library
This EthernetWebServer_SSL_STM32 Library is a simple yet complete TLS/SSL WebClient and non-TLS/SSL WebServer library for STM32F/L/H/G/WB/MP1 boards using Ethernet shields. The functions are similar and compatible to those of ESP32 WebServer and ESP8266WebServer libraries to make life much easier to port sketches from ESP8266/ESP32.
This EthernetWebServer_SSL_STM32 Library adds TLS 1.2 functionality to EthernetClient, using BearSSL as an underlying TLS engine.
Releases v1.1.0
1. Initial coding for STM32F/L/H/G/WB/MP1 boards (with 32+K Flash) running LAN8742A, W5x00 or ENC28J60 shields using SSL.
2. Supporting Built-in LAN8742A using STM32Ethernet library.
3. Supporting W5x00 using Ethernet, EthernetLarge, Ethernet2 and Ethernet3 libraries
4. Supporting ENC28J60 using EthernetENC and UIPEthernet libraries
Currently Supported Boards
1. STM32 boards with built-in Ethernet LAN8742A such as :
- Nucleo-144 (F429ZI, F767ZI)
- Discovery (STM32F746G-DISCOVERY)
- All STM32 boards (STM32F/L/H/G/WB/MP1) with 32K+ Flash, with Built-in Ethernet
2. STM32F/L/H/G/WB/MP1 boards (with 32+K Flash) running W5x00 or ENC28J60 shields)
- Nucleo-144
- Nucleo-64
- Discovery
- Generic STM32F0, STM32F1, STM32F2, STM32F3, STM32F4, STM32F7 (with 64+K Flash): x8 and up
- STM32L0, STM32L1, STM32L4
- STM32G0, STM32G4
- STM32H7
- STM32WB
- STM32MP1
- LoRa boards
- 3-D printer boards
- Generic Flight Controllers
- Midatronics boards
Examples:
1. AdvancedWebServer
2. HelloServer
3. HelloServer2
4. HttpBasicAuth
5. MQTTClient_Auth
6. MQTTClient_Basic
7. MQTTClient_SSL
8. MQTTClient_SSL_Auth
9. PostServer
10. SimpleAuthentication
11. UdpNTPClient
12. UdpSendReceive
13. WebClient
14. WebClientMulti_SSL
15. WebClientRepeating
16. WebClient_SSL
17. WebServer
Debug Termimal Output Samples
1. The following is the sample terminal output when running example WebClient_SSL on NUCLEO_F767ZI with LAN8742A Ethernet & STM32Ethernet Library
Start WebClient_SSL on NUCLEO_F767ZI with LAN8742A Ethernet & STM32Ethernet Library
[ETHERNET_WEBSERVER] =========================
[ETHERNET_WEBSERVER] Default SPI pinout:
[ETHERNET_WEBSERVER] MOSI: 11
[ETHERNET_WEBSERVER] MISO: 12
[ETHERNET_WEBSERVER] SCK: 13
[ETHERNET_WEBSERVER] SS: 10
[ETHERNET_WEBSERVER] Board : NUCLEO_F767ZI , setCsPin: 10
Currently Used SPI pinout:
MOSI:11
MISO:12
SCK:13
SS:10
Using mac index = 10
Connected! IP address: 192.168.2.139
Connecting to : www.arduino.cc, port : 443
Connected to www.arduino.cc
Took: 480
Using micros()
2A 5C A7 84 DC 48 AB 3E C6 80 4E E D8 88 4C FE
Using analogRead()
3E 76 9B B8 CD E9 F4 FE 8 D 12 14 C 1B 20 1D
HTTP/1.1 200 OK
Date: Tue, 10 Nov 2020 08:33:53 GMT
Content-Type: text/plain
Transfer-Encoding: chunked
Connection: close
Set-Cookie: __cfduid=de77338a7e6c914c4dd309cecf5dcdb3b1604997233; expires=Thu, 10-Dec-20 08:33:53 GMT; path=/; domain=.arduino.cc; HttpOnly; SameSite=Lax
Last-Modified: Wed, 02 Oct 2013 13:46:47 GMT
Vary: Accept-Encoding
Access-Control-Allow-Origin: https://www.arduino.cc
Access-Control-Allow-Credentials: true
Access-Control-Allow-Methods: GET, POST, PUT, DELETE, OPTIONS
Access-Control-Allow-Headers: Accept,Authorization,Cache-Control,Content-Type,DNT,If-Modified-Since,Keep-Alive,Origin,User-Agent,X-Mx-ReqToken,X-Requested-With
Strict-Transport-Security: max-age=500; includeSubDomains
X-Frame-Options: SAMEORIGIN
X-Content-Type-Options: nosniff
X-XSS-Protection: 1; mode=block
CF-Cache-Status: DYNAMIC
cf-request-id: 0652e352a40000b683be849000000001
Expect-CT: max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct"
Server: cloudflare
CF-RAY: 5efe6e643ecfb683-YWG
8d7
        .;;;;;;;;;;;`                :;;;;;;;;;;:     TM
0
(EthernetSSLClient)(SSL_WARN)(connected): Socket was dropped unexpectedly (this can be an alternative to closing the connection)
Disconnecting.
Received 3324 bytes in 0.5398 s, rate = 6.16 kbytes/second
2. The following is the sample terminal output when running example WebClientMulti_SSL on NUCLEO_F767ZI with ENC28J60 & EthernetENC Library
Start WebClientMulti_SSL on NUCLEO_F767ZI with ENC28J60 & EthernetENC Library
MOSI:11
MISO:12
SCK:13
SS:10
Connecting to www.arduino.cc...
Took: 2261
HTTP/1.1 200 OK
Date: Tue, 10 Nov 2020 09:24:02 GMT
Connection: close
Set-Cookie: __cfduid=d588a3b3b35b8e56eb1b7031f46c283b91605000242; expires=Thu, 10-Dec-20 09:24:02 GMT; path=/; domain=.arduino.cc; HttpOnly; SameSite=Lax
cf-request-id: 0653113b580000b65f28017000000001
Server: cloudflare
CF-RAY: 5efeb7d88c03b65f-YWG
8d7
0
Disconnecting.
Received 3324 bytes in 0.3587 s, rate = 9.27 kbytes/second
Connecting to www.cloudflare.com...
Took: 1683
HTTP/1.1 200 OK
Date: Tue, 10 Nov 2020 09:24:09 GMT
Connection: close
Set-Cookie: __cfduid=d14958859d5dad28f89ca90056c3547b91605000249; expires=Thu, 10-Dec-20 09:24:09 GMT; path=/; domain=.www.cloudflare.com; HttpOnly; SameSite=Lax; Secure
Access-Control-Allow-Origin: *
Server: cloudflare
CF-RAY: 5efeb8061b0eb65f-YWG
Expires: Thu, 01 Jan 1970 00:00:01 GMT
Cache-Control: no-cache
bb
fl=168f4
h=www.cloudflare.com
ip=76.10.180.220
ts=1605000249.298
visit_scheme=https
uag=SSLClientOverEthernet
colo=YWG
http=http/1.1
loc=CA
tls=TLSv1.2
sni=plaintext
warp=off
gateway=off
0
Disconnecting.
Received 3998 bytes in 0.0656 s, rate = 60.98 kbytes/second
3. The following is the sample terminal output when running example WebClient_SSL on NUCLEO_F767ZI with W5x00 & Ethernet3 Library
Start WebClient_SSL on NUCLEO_F767ZI with W5x00 & Ethernet3 Library
[ETHERNET_WEBSERVER] =========== USE_ETHERNET3 ===========
Ethernet3 W5500 init, using SPI_CS = 10, number of sockets = 4
MOSI:11
MISO:12
SCK:13
SS:10
SPI_CS:10
Took: 421
HTTP/1.1 200 OK
Date: Tue, 10 Nov 2020 08:42:12 GMT
Connection: close
Set-Cookie: __cfduid=dc0d46f4fc488c76630a1c7327c64d5861604997732; expires=Thu, 10-Dec-20 08:42:12 GMT; path=/; domain=.arduino.cc; HttpOnly; SameSite=Lax
cf-request-id: 0652eaf1aa0000cabc368f8000000001
Server: cloudflare
CF-RAY: 5efe7a95dacecabc-YYZ
alt-svc: h3-27=":443"; ma=86400, h3-28=":443"; ma=86400, h3-29=":443"; ma=86400
8d7
0
Disconnecting.
Received 3405 bytes in 0.4360 s, rate = 7.81 kbytes/second
khoih-prog
Re: EthernetWebServer_SSL_STM32 Library now supports TLS/SSL Client
Major Release v1.2.0
1. Add high-level HTTP and WebSockets Client by merging ArduinoHttpClient Library
2. Add many more examples for HTTP and WebSockets Client.
3. Add Version String.
Release v1.1.2
1. Add SSL debug feature.
2. Enhance examples.
Release v1.1.1
1. Permit sites with "Chain could not be linked to a trust anchor" such as mqtt.thingstream.io.
2. Add example MQTTS_ThingStream to demonstrate new feature
khoih-prog
Releases v1.3.0
1. Add support to LAN8720 Ethernet for many STM32F4 (F407xx, NUCLEO_F429ZI) and STM32F7 (DISCO_F746NG, NUCLEO_F746ZG, NUCLEO_F756ZG) boards.
2. Add LAN8720 examples
3. Add Packages' Patches for STM32 to use LAN8720 with STM32Ethernet and LwIP libraries
Releases v1.2.1
1. Clean-up all compiler warnings possible.
2. Add Table of Contents
