Problem with Port
How to install STM32 core into the Arduino IDE, and any OS specific issues
Answers: 8
Re: Problem with Port
That is a clear sign that your driver is not installed or activated correctly.
Look for a "Unrecognized device" in your device manager in the case you get that message, then try to update that driver automatically.
wegrei
Post by wegrei »
Hi Stevestrong,
jeah, thats what happensb after getting my board into boot mode:
Have tried to update the driver automatically many times. No success. After unpluging and repluging the board the board is recognized again but as soon as I get it into boot mode it falls off.
wegrei
Post by wegrei »
Here in more detail:
wegrei
Post by wegrei »
And as you see it falls always back to the original windows driver. Do not know how to get rid of that.
You best bet is to reinstall the cube programmer.
But before do that I would clean the USB driver.
You can use USBDeview.
https://www.nirsoft.net/utils/usb_devices_view.html
Answers: 8
I would try this one: https://www.st.com/en/development-tools ... 32080.html
Then restart the computer.
wegrei
Post by wegrei »
@ fpiSTM
OK, thats what I have done. Tried to deinstall the STM Cube. Did not work, as one deinstallation file was missing. Removed it then manually. Removed also all unused USB entries using the USBDeview. Then I cleaned the entire computer with a reg scan and repair program. After that I reinstalled the STM Cube and drivers. After plugging the board in the first time, it recognized the black pill (happy):
Then after going into the boot mode, the following happened:
and it was not visible any more.
URGH that drives me crazy. Maybe I completely reset my computer and reinstall the OS from the beginning on. Something in the background might screw everything up. This drives me crazy.
@ SteveStrong
This I already tried
wegrei
Post by wegrei »
Now I have installed everything on a stone age old Laptop under Windows 7.
Guess what? It works. Buuummmmm....
I do not know what my Windows 10 computer is doing, strange....
At least I can start programming.
Thanks for all your help so far, have a good one :P
Answers: 8
Have you installed the drivers with admin priviledges?
Jwolffbrandt
Post by Jwolffbrandt »
Tie pin A10 to ground during the button presses to bootload.
Had the exact same problem and tried the same fixes. The only difference was I knew it worked when it wasn't on a bread board and it stopped working when I plugged it into an empty bread board. That made me think it was a floating pin issue. I moved a jumper around from ground to different pins and somehow it works if you ground out pin A10. (It also seems to work if you pull it to 5v). I don't know why this happens but I can replicate it over and over.
Return to “Installation and OS related”
