@ag123
1. Uploaded through 'ST-Link 2'.
2. Upload was successful. It goes in well.
3. However, the 'control board' does not operate.
https://drive.google.com/file/d/1dWZzM7 ... sqIOJ/view
Q1) By any chance, does it work by inserting the 'bin' file I created?
Q2) After inserting, what actions should I take on boot1 and boot2?
I want to create a 'hex' file via 'STM32Duino' (Arduino sketch).
Re: I want to create a 'hex' file via 'STM32Duino' (Arduino sketch).
which core are you using 'libmaple' core
e.g. this
or 'official' STM core
In both cases, you need to select st-link as upload method to build the sketch, that change the start location and memory layout
and in addition, did you try a 'blink' sketch? like this?
these are the 'basic' things, the led need to blink. then for Serial, make sure to select USB CDC ACM as Serial for the 'official' STM core.
e.g. this
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, ! digitalRead(LED_BUILTIN));
delay(500);
there is another thing about 'stm32f103c8 blue pill' type boards, some of them use a 10k ohm pull up resistor instead of a 1k ohm pull up resistor for USB.
that cause some problems for some computers, but works ok on a lot of others.
linux has a little utility called usbreset, does a usb reset ('single ended zero')
https://github.com/jkulesza/usbreset
that can get the port to enumerate again
in windows, I think one way is to disable and enable the device in device manager.
@ag123
Thank you very much for your kind explanation.
'You need to select st-link as upload method to build the sketch'
To recap:
1. Firmware can be uploaded to programs other than Arduino Sketch through the 'bin' file.
2. When creating '.bin' in the Arduino sketch, it must be created through 'ST-LINK'.
1,2 with success. Thank you sincerely.
To recap:
