Stm32f103c8t6 pulses
Related to the the forum.
nikjayswal
Post by nikjayswal »
Need some idea or suggestion i want to read pulses fast as possible want to measure pulses upto 2MHz. The pulseIn/pulseInLong has limitions so it can not work greater than 100KHz.
stas2z
Answers: 8
Re: Stm32f103c8t6 pulses
Post by stas2z »
im not sure it's possible with any core, but using HAL/CMSIS or in general as a concept it can be implemented using two timers
one timer in input capture mode capturing raising (or falling) edge, and second timer triggered by first timer overflow
target frequency will be timer2 count * timer 1 overflow value / time
Answers: 24
if what you need is square waves, this logic analyzer on stm32f401 black pill goes up to 5mhz
viewtopic.php?f=10&t=116
and this logic analyzer that runs on stm32f103 (blue pill)
https://github.com/ddrown/stm32-sump
does 7 mhz
dma can normally handle square wave trains in the low mhz regions. apparently it is a challenge (possibly not achievable) to attempt high mhz transfers with simply gpio and dma. for even higher mhz than 5mhz, only specialised interfaces such as high speed ulpi 60mhz, ethernet 50mhz can do those
nikjayswal
So had any ideas for frequency upto 200Khz or 300khz ? Without using or alternatively pulseIn/pulseInLong ?
Answers: 8
You got 2 possible solutions.
Why don't you like them?
