F407VET6 minimal dev board
BennehBoy
Post by BennehBoy »
I wanted to buy a few more FK407M1's but they seem to have gone up in price quite a bit - 11.35GBP each
Whilst searching I found this board -> https://www.aliexpress.com/item/4001249257969.html
A fair amount cheaper, but built quality looks lower, cheaper SD slot & micro USB instead of USB C.
Has anyone tried these?
Re: F407VET6 minimal dev board
I never used this one. Anyway nice form factor.
BennehBoy
Post by BennehBoy »
I've ordered a few, I'll report back - should work just fine with the Generic F407VE variant, but I guess I'll need to create a board specific one to get SDIO & the onboard SPI memory chip enabled (although the latter probably just depends on which pins they decided to wire it against).
BennehBoy
Post by BennehBoy »
Boards arrived, they seem to work quite nicely.
Thanks for the feedback ;)
BennehBoy
Post by BennehBoy »
Can #if define be used in build_opt.h ?
The reason I ask is I frequently compile my project code against multiple boards, I handle this with various #if defined statements
#if defined ARDUINO_DIYMROE_F407VGT // STM Core SPI SD
#include "LRDuinoDefs407VE.h"
#define ARCH_DEFINED
SPIClass SPI_2(PB15, PB14, PB13); // Max31856  on MOSI, MISO, CLK - SPI2 on F4,  STM Core
It would be useful to be able to include different HAL modules based on the board type, eg for boards that have SDIO
I can work around it, but at present I have to edit the variant files directly.
BennehBoy
Post by BennehBoy »
Excellent, hadn't spotted that.
flyboy74
Post by flyboy74 »
You can also get that board with larger flash if you need it and also if you shop around you will find it cheaper too see both variants here https://www.aliexpress.com/item/4001004 ... web201603_
I have a number of them here and have been using them for awhile as my main go to board because they certainly can do everything that I need and am cheap as chips.
