[Solved] Bounce Library
Korb
Post by Korb »
Hello
my name is Marcus and I am pretty new to this complete "Blue Pill Thingy" :)
I'm trying to make the Arduino Bounce2 Lib run, without any success. :?
C:\Users\m_kor\Documents\Arduino\libraries\Bounce2\Bounce2.cpp: In member function 'void Bounce::attach(int, int)':
C:\Users\m_kor\Documents\Arduino\libraries\Bounce2\Bounce2.cpp:36:20: error: invalid conversion from 'int' to 'WiringPinMode' [-fpermissive]
pinMode(pin, mode);
In file included from C:\Users\m_kor\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2020.1.24\cores\maple/wirish.h:55:0,
from C:\Users\m_kor\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2020.1.24\cores\maple/Arduino.h:30,
from C:\Users\m_kor\Documents\Arduino\libraries\Bounce2\Bounce2.cpp:4:
C:\Users\m_kor\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2020.1.24\cores\maple/io.h:110:6: error: initializing argument 2 of 'void pinMode(uint8, WiringPinMode)' [-fpermissive]
void pinMode(uint8 pin, WiringPinMode mode);
exit status 1
Any Ideas?
Cheers Marcus
by fpiSTM » Fri Feb 14, 2020 6:49 am
Simply that the library do not cast the pin to a WiringPinMode type and the compiler do not allow this.
https://github.com/thomasfredericks/Bou ... #L193-L198
    virtual void setPinMode(int pin, int mode) {
#if defined(ARDUINO_STM_NUCLEO_F103RB) || defined(ARDUINO_GENERIC_STM32F103C)
        pinMode(pin, (WiringPinMode)mode);
#else
        pinMode(pin, mode);
You can redefine your own setPinMode to avoid the issue or define the switch before the header include.
Anyway, I would open an issue to the library because the define used to do this seems not enough to handle properly the correct call in all case.
As it seems you use Roger's core, it should use a generic define like:
ARDUINO_ARCH_STM32F1
Answers: 4
Re: Bounce Library
#else
        pinMode(pin, mode);
Answers: 4
Re: Bounce Library
Korb
Re: Bounce Library
Post by Korb »
Thank you so much, now it's working :D
