use of SPI2 on SPI- or Ethernet lib
Ralf9
Post by Ralf9 »
is there a possibility to use on Maple Mini SPI2 on the SPI- or Ethernet library?
I don't find any way at the SPI- or Ethernet library, how I can specify that I want use SPI2
Thank you
Ralf
Re: use of SPI2 on SPI- or Ethernet lib
Ralf9
Post by Ralf9 »
With this it works with the pins of SPI2
	#define csPin	31
	#define mosiPin 28   // MOSI out
	#define misoPin 29   // MISO in
	#define sckPin  30   // SCLK out
	SPI.setMISO(misoPin);
	SPI.setMOSI(mosiPin);
	SPI.setSCLK(sckPin);
	SPI.begin(); //Initialize the SPI port.
	SPI.setBitOrder(MSBFIRST);
	SPI.setDataMode(SPI_MODE0);
	SPI.setClockDivider(SPI_CLOCK_DIV16);      // Slow speed (72 / 4 = 4.5 MHz SPI speed)
When I try this
	#include <SPI.h>
	SPIClass SPI2(mosiPin, misoPin, sckPin);
I become on the Arduino IDE the follow Errors
/home/ralf/.arduino15/packages/STM32/hardware/stm32/1.8.0/system/Drivers/CMSIS/Device/ST/STM32F1xx/Include/stm32f103xb.h:654:43: error: expected ')' before '*' token
  654 | #define SPI2                ((SPI_TypeDef *)SPI2_BASE)
sketch/cc1101.h:18:11: note: in expansion of macro 'SPI2'
   18 |  SPIClass SPI2(mosiPin, misoPin, sckPin);
I want use cc1101 Modules on SPI2 and a W5500 Lan Modul on SPI1
My sketch should work too on an existing hardware with the cc1101 Modules on SPI1 and the Lan Modul on SPI2.
Ist there a a possibility to use the W5500 Lan Modul on SPI2?
You couldn't call your SPI2 instance SPI2 because it is a CMSIS definition.
So call it SPI_2 for example.
