[Solved] Problem with Hardware Timer Examples
Posted: Tue Mar 10, 2020 12:34 pm
Hello everyone,
Now, I'm studying on how to use HardwareTimer Library as described in https://github.com/stm32duino/wiki/wiki ... er-library
I've tested the Timebase_callback.ino example, it's worked as expected.
However, when I tried to run the All-in-one_setPWM.ino or PWM_Fullconfiguration.ino, there was no output at both LED_BUILTIN pin (D13) and D3 pin (tested with oscilloscope)
The board I'm currently using is "Nucleo-F303K8"
I don't think that there should be any change in the code, or am I missing something?
Any help would be grateful
Thanks,
Thanks,
